Idles fluctuates?
Started by turbocamino, October 02, 2013, 02:00:23 PM
Quote from: turbocamino on October 03, 2013, 04:35:00 PM
The tip or thought of the idle speed got me thinking about flow around at the blades...which in turn had me focus there....which did the trick(thank you very much)  Concerning idle speed though..at anything over 1000 idle,  i dont like how hard it bangs into gear when i drop it in first...i have been over the mounts for condition and tightness and all appears fine..may just be my personal preference? so i settled on 1000/975.  I forget the brand of individual air filters i have but they look like a basic K&N gauze type filter...i havent oiled them if a long time as i have read oiling can be an issue?.  I do soak them in simple green and blow them out every spring...they do appear very clean when done. I could oil them then blow them dry?    Nevertheless, dirt came from somewhere...Is foam a better choice?   Carbs have never been synched..no doubt, at 19K,it could stand to be done...The bike has always ran flawless,so i let it be.
That's the problem, gauze filters MUST be oiled, that is what makes them "filter".... Without oil, they let every little particle of crap thru! Even oiled, they let too much fine, silty crap thru....   Foam filters, such as UNIs, do a MUCH better job of catching the dust.
Bminder
Quote from: ribbert on October 03, 2013, 07:09:21 PM
Don't believe everything you read on the net.
I believe it was Abraham Lincoln who said that.
Billy Minder
92 FJ1200 ABS
Alf
This summer I´ve been travelling across Europe with my friend JC´ 3CV FJ
The bike have done only subtle mods: tyre, brakes & suspension. The engine and carb set up is STD and with OE silencers. KN filter on OE airbox.
The bike was carefully revised by myself before to start my hollydays
The idle fluctuated a lot. It was near impossible to leave it around 1000 rpm: or it was so low that the bike stalled or it was above 1200 rpm. We played with mixture screws without solution. Like a bonus, the distribution chain noise was clear, so we thought about a defective distribution chain tensioner, and the brakes had a wooden feeling, although the set up is the same than on my bike
After 10.000 hard ridden kms in 6 weeks, travelling fast alone and with passenger, including 2 closed track incursions, the bike run like a dream, with sweet idle, no noises and even more power. The brakes bit like furious piranhas and the only negative point was that the clutch slippage was frustrating when ridding hard. My bike have done the clutch mod
You have to ride an FJ like it deserves
FJ1100mjk
Quote from: Alf on October 04, 2013, 03:12:02 AM
You have to ride an FJ like it deserves!!!!! [emphasis added]
+1!
Iron Balls #00002175
www.ironballs.com
Alf
turbocamino
Quote from: RichBaker on October 03, 2013, 07:21:59 PM
Thanks ...i think i will oil my currant filters...i found a can of K&N filter oil on the shelf...and next spring get the foam models...Randy has a nice set.
