rear wheel swap
Started by greasemonkey, August 25, 2013, 08:52:35 PM
greasemonkey
I'm sure this is already on here somewhere but I can't find it. I'm building my 1100 for the drag strip and I'm looking to save on weight and go with a wider tire at the same time. Is there any 17" wheel that is a direct swap other than a possible rotor swap? And any info on fitting a extended swingarm off of a cbr900rr would be greatly appreciated.
oldktmdude
Quote from: greasemonkey on August 25, 2013, 08:52:35 PM
If you're fitting a swingarm off a Honda CBR900RR to your 1100, the easiest rear wheel swap surely must be obvious?
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Here are the 2 write ups on the GSXR rear wheel mod.
http://www.fjowners.com/index.php?topic=3380.0
http://www.fjowners.com/index.php?topic=2465.0
Instead of trying to fit a CBR900 swing arm. Have you considered finding an extended FJ swing arm, or fabricating your own? I have seen FJ swing arms for sale on eBay that have had 2" and 4" sections welded in. IMO The easiest and least expensive would be to Modify a FJ swing arm.
greasemonkey
I'm actually going to extend the stock swingarm but if the cbr would fit I have access to it free of cost and I wouldn't have to swap the rear wheel.
greasemonkey
Fred, thanks for the links they are exactly what I was looking for and best of all I have all the parts at work. Thanks again.
