rubber chain guides on chain guard
Started by sean91fj, July 06, 2013, 04:29:55 AM
sean91fj
Hi,
Not sure what they are called but I need to get hold of some new rubber chain guides that protect the swingarm ect from the chain?
Would be easier to get if I knew what they were called  :biggrin:
cheers Sean
FJ111200
I've always known it as the chain slider.  (popcorn)
big r
Quote from: sean91fj on July 06, 2013, 04:29:55 AM
Hi,
cheers Sean
I think they are called "2KT-22151-00-00 SEAL,GUARD" . That's the part number for a 1990 FJ. I think there is two different styles so make sure you get the correct one for your year of FJ. No expert, just thinking out load.  :yahoo: I think Randy has some and they are still listed as available from Yamaha at least for the 1990.
poker007
hi   If you need 1 for a 84,85,86, good luck i could not find 1 for my 85 :dash1: i will just replace the swing arm some day i guess, There discontiuued,I
mean that is so stupid,  for yamaha to stop makein a part that is  so needed :ireful:
Mark G
1980 GT80( dirt) gone 1979 IT250  ( have)
1975 MX400(dirt) gone
1979 RD400 gone
1980 KZ1000st/ shattered right arm/ (ouch) gone thank GOD!
1995 FZR600 ( missed @gone)
1985 FJ1100 (TEL DEATH; DO WE PART)
Quote from: poker007 on July 07, 2013, 11:30:07 AM
hi   If you need 1 for a 84,85,86, good luck i could not find 1 for my 85 :dash1: i will just replace the swing arm some day i guess, There discontinued,I
Mark G
Hard to believe that you can't adapt a newer version on to the older swing arm. Also get on e bay and look at other swing arms from other manufactures to see if anything looks like it might adapt.
Hi,
cheers Sean
Sean,
Boats.net says they have the Seal Guard (sells for US$51.00) here:
Index #28 Seal guard, 1991 FJ1200:
http://www.boats.net/parts/search/Yamaha/Motorcycle/1991/FJ1200B/SWING%20ARM/parts.html
Better call and check, though.
As already mentioned, I do stock the swing arm guide. They are in stock and you will probably see it on Wednesday if you order on Monday.
Would of thought all years were the same
sean91fj
ok great ! Thanks for your help everyone much appreciated !   :good2:
