battery negative cable....
Started by Antonn3, May 26, 2013, 12:21:50 AM
Antonn3
Hello, I'm in the process of rebuilding my FJ1100 and I forgot, where does the cable coming off the battery negative terminal go to on the engine?
Thanks,
Tony
Quote from: Antonn3 on May 26, 2013, 12:21:50 AM
Thanks,
Tony
Behind the battery, look down and you should see a bolt on the engine. Out of memory it's about 6-8 inches down there. You should be able to see where it was connected.
flips
Hi Anton
The negative cable on my 86 1200 bolts on the middle bolt  bellow where the engine casing rises up for the rear upper engine mount.
Hope this helps.
Cheers  :drinks:                               about* here
Jeff P
Stay rubber side down.
Derek Young
Make sure you clean the contact area well before connecting the cable. You need a good connection to run the starter.
Derek
1986 FJ1200 (R.I.P.)
Nanaimo, British Columbia
