Exhaust / muffler question
Started by FJ12, May 11, 2013, 05:32:23 PM
FJ12
Hi all, can anyone tell me if a stock exhaust off an 88 model would fit my 93, mainly want to use the mufflers but would probably change the whole lot. I am just not sure if mounting bracket on muffler is in same spot as mine so don't want to buy if not compatible.
Thanks
Colin
86 & 93 FJ 'S
The mount point may be slightly different, I'm not certain.
However, if so it is easy to make a little bracket to get it to fit.
Talk to FJ11.5 (Rod) who is also in Burnie, he'll know.
FJ12
Does anyone have a 88 with stock pipes they could measure for me
Ta
Colin
86 & 93 FJ 'S
HARTLESS
use the search function! im pretty sure I have seen this question several times, and from what I can remember you just have to make new brackets because they are a little different....but then again I have horrible memory :drinks:
The mufflers mount differently on the '91 and later models. They have a frame loop and I think it's lower than the sideplate mounts on the earlier bikes...
My 88 has a 4/1 ,but mounts are different than the standard set up on the 84 , , you can buy muffler brackets on ebay , I havnt lived in burnie for ten years, but I'm not too far from you mate,
FJ12
G'day fj11.5, thanks for info, yes we must definitely catch up one day, keep in touch and we can hopefully catch up before the weather turns totally crap
86 & 93 FJ 'S
No worries mate, , I was out today for an hour or so, great weather, just a little cool,  mainly heading back into the hills
