Fuel Gauge Needle Fell of Its Shaft - How To Repair?
Started by FJ1100mjk, March 20, 2011, 10:30:43 PM
FJ1100mjk
Hi:
I recently bought a used,  non-running  '85. While I was cleaning it up today, I noted (scratched right exhaust canister, and a few blemishes on its right side) that it looks like it was laid down on it. I'm guessing that when it happened, the fuel gauge needle popped off its shaft, because it is lying at the bottom of the gauge.
Is it possible to disassemble the gauge cluster to get at the fuel gauge, and re-install the needle on its shaft again? Has anyone disassembled the instrument cluster before, if so, can you provide directions and warnings to do so?
Thanks in advance.
Marty
Iron Balls #00002175
www.ironballs.com
oldktmdude
  G'day Marty, you need to take the fairing off first, remove the headlight assembly (2 bolts plus adjuster bolt) then remove the 2 bolts holding the instrument panel in place. Once you have the panel out you only need to remove the 5 phillips head screws that retain the clear plastic instrument lens in place. You now have access to the gauge faces. Sorry no experience with re-installing a gauge needle. Maybe some type of bonding agent is required (loctite)? Somebody else may want to answer this.   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Marty, follow Pete's instructions for dis-assembly. If worse comes to worse, I have a gauge you can have in perfect working order from my '91.
yep gule is the way ahead.
While your at it, I would glue a 'needle stop' on the face of the gauge to prevent it from going bananas.
On the advice of mr Bean, I used a small tack, painted black, then super glued on to the dial face at the top of the tank full marks.
Scooterbob
Had to super glue mine back on about a month ago too.  Not too difficult.  Holding so far...........
-----Bob G.-----
FJ1100mjk
Guys:
Thanks for the quick input and fix for the gauge's needle. It's much easier to fix than I thought that it would be.
Thanks too, for the tip on putting a hard-stop in to keep the needle from spinning around. By the way, what is the cause of this anyways?
Marty
www.ironballs.com
Don't forget to unscrew/remove the trip meter reset button on the front before removing the gauge lens.
