Not quite sure?
Started by fb747, February 15, 2011, 07:40:58 AM
fb747
Can any one confirm that these pipes will fit my 89???
It's on a Japanese auction site and the seller states that they don't know what there off.
Any help would be appreciated.
Cheers, Ben.
Life's pretty straight without twisties.
fb747
Below is a yahoo translate of the description... i got a laugh out of it.
Is it CBR1000F? Is it GSX-R1100? Is it FJ1200? できませでした specific by conformity car. I thought that it was a GPZ1000RX area, but was not able to put it on. I think that it is displacement volume use very much, but I take ... form into account, and please point out one examination to understand. It is space around 325mm from around 450mm in height / the EG plug bottoms from ・・・● EG plug diameter around 42mm / flange pace around 58mm / stud bolt loss diameter around 8mm / Eki pie diameter around 41.5mm / the EG plug top to the bottom of the set region to the upper part of the set region. I miss it to ・・・● wound and first Eki pie? Is it a light dent? It is a thing having the などありますが big damage is not popular and use it enough. I examine one to understand by all means, and please point it out! It was a joint spring missing part. ...●It is silencer plug diameter around 54.5mm.
fb747
more picutres.
Any one got a clue???
Ben, looking at the pictures, I doubt they are for an FJ.....the length of the headers suggest maybe an FZ1 or something with a shorter distance from exhaust ports to the bottom of the sump......but not long enough for an FJ.
But I could be wrong!
Travis398
I think Harvy is right, But I could be wrong too.
Headpipes don't appear to be correctly shaped for an FJ.
This is for an FJ, notice the 1 + 4 pipes are a more flat shape, as there's no frame to tuck into there.
Blitzen
Okay, I'll throw my 2 cents in and agree with the others that it is not for an FJ because it looks like the spacing between the header pipes is equal.  That is to say it looks like it is for an engine that doesn't have a cam chain between cylinders 2 & 3.
Kopfjaeger
i am in the opinion of the original post...i reckon its for a GPZ 1000 rx... looks the same as my  2 into 1's at the headers...
Travis398
The FJ header has a pretty good angle on it too, the original pics look a lot straighter
