Ideas on removal of insert from cylinder
Started by moparman70, January 21, 2026, 10:34:38 AM
This is like the "Make it Work" scene in Apollo 13. Problem solving...
Flynt
Quote from: FJmonkey on January 27, 2026, 10:34:34 AMThis is like the "Make it Work" scene in Apollo 13. Problem solving...
I agree...  put off the mechanic's fingers for a while.  I'm sure there's a harder way that'll work.
T Legg
Quote from: Flynt on January 27, 2026, 10:36:39 AM
The claw was their first method attempted.
  "We have a bore scope and we can see it -- we also are able to grab it with some flexible wire pinchers but the unable to retrieve it with the pinch grabbers due to the overall width of the grabbers once they hold the brass insert.  So basically can pull it through the hole."
T Legg
86FJNJ
what about a drop of fast curing super glue on the tip of the straw. you said you kind of got it with the straw so maybe some superglue on the straw edge and then once the straw touches the piece hold it for a minute or two and then try to vacuum it out
Eric, Robert and I agree, the secret to success is with adhesives.
If you can't mechanically grab it, or hold it with vacuum, then as Timothy Leary suggested, better living thru chemistry...so to speak.
Can we start a betting pool? I'm in for 5 bucks... :gamer:  :gamer:  :gamer:  :gamer:
Waiex191
I'd wrap some good duct tape inside out around a straw.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Billy Bananahead
Bite the bullet and pull the head off. Then clean the carbon off the valves and piston crowns. (popcorn)
Sparky84
Quote from: Billy Bananahead on January 28, 2026, 05:49:24 AMBite the bullet and pull the head off. Then clean the carbon off the valves and piston crowns. (popcorn)
Port/polish, bigger valves , list goes on
Btw Good Luck Gratis
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Gratis
Today was a good day. I :morning2:  got that damn brass piece out. I appreciate all the comments and suggestions, here's what worked: First, borescope. No way to do this with out that. Knowing where the part was I could grab it with the claw, position it TDC and drop it there. Then with the borescope inside a straw I could precisely place the straw, extract the camera and place the vacuum on the straw. Lift the straw with the piece out enough to grab it with hemostats. Then while holding it with the hemostats slip a bent screwdriver under the part for leverage. Then while jamming the piece with the screwdriver dremel a hole into it. Now put a punch in the hole and wobble it back and forth while pulling up. Hope that makes sense. Finally moving on with this project!
Gratis,
Great news! Glad that worked out.
While you have the vacuum out, I suggest that you vacuum out the cylinder to extract any tiny pieces that may remain in the cylinder.
Just a thought . . .
The thorn is out, the pain is gone. What a chore for such a small item. Well done.
MarioR
It does not matter how slowly I go as long as I do not stop.
FJ1200W
Perseverance pays off!
Well done not over done
Columbia, Missouri
USA
