Keihin FCR 41's?
Started by fjryder, June 04, 2010, 04:12:11 AM
fjryder
Has anyone run Keihin FCR 41's on an FJ? Mine is an FJ1100 that is getting a 1250 kit and probably cams/valve work. Thanks.
Over the last couple of years, I have been told that the sidedraft Keihin FCR's have been very hard to come by. Very rare.
IIRC Frank M and Steve C both have monster 1349cc motors in their FJ's, and they have only needed the 39 FCR's
Therefore, for only a 1250cc motor the 41's sound a bit big....however if 41's are all you can get......
The FCR's have been reported to be superior over the Mikuni FS38's but, then again, the FCR's have no choke function.
Frank, Steve?
waaaaaaaay too big for the FJ......    im fairly sure the spacing would be all wrong for the FJ unless they were originally bought specifically for a drag racing FJ
my 1349 pulls to redline (hard) with the FCR39's      i can get about 40mpg if i take it real easy or i can hammer out some serious KOoKaLoo and drop that right on down to about errrrrr 27 or so  :diablo:
stock are 36 and are very capable of working well in concert with a 1250 motor.... if you go too big on the carb you lose the intake velocity.... according to my sources the FJ has a inefficient combustion chamber so you need to make sure you get good fill by keeping the intake velocity high with a smaller diameter carb.  the mikuni 38's might be a good choice for more on the big end BTBH i had some RS38's and i didnt care for them and their forearm pumping throttle spring even if they did have a choke.
ze kookaloo is goot no?   :good2:
