FJR1300 brake m/c
Started by shudnobetter, June 28, 2018, 06:07:34 PM
shudnobetter
Just decided to upgrade to R1 calipers, new discs and a FJR1300 m/c. The m/c is en route to me but I reckon it doesn't have a FJR brake lever with it. Can I re-use the FJ1200 lever or do I need the FJR lever to match the m/c?
Still a newbie to be kind if this is a well worn question.
If at first you don\'t succeed, maybe parachute jumping isn\'t for you!
I doubt the FJ lever will fit the FJR master. You might also review this recent post. http://www.fjowners.com/index.php?topic=17917.msg180647#msg180647
There is no reason to ask the same question in two different areas....
I can tell you for a fact that the original FJ lever will not fit the FJR master cylinder.
You will have to obtain an FJR lever.
You will also have to address the brake light switch. It uses a different connector.......
FJ1100mjk
Quote from: Pat Conlon on June 28, 2018, 07:09:05 PM
Iron Balls #00002175
www.ironballs.com
shudnobetter
Quote from: FJmonkey on June 28, 2018, 07:04:32 PM
Helpful, thanks.
shudnobetter
Noted, thanks.
shudnobetter
Quote from: FJ1100mjk on June 29, 2018, 05:47:46 AM
And, you might say...no need to be told twice not to ask a question twice... :nea:
JPaganel
Quote from: Firehawk068 on June 28, 2018, 10:51:58 PM
You can buy the connector.
The stock number is M3PLPS on this page: http://www.oregonmotorcycleparts.com/connectors.html
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
RPM - Robert
FJR Brake Master Cylinder Switch Is the switch you will need to make the brake lights work properly.
JOMPPA10
fjr master c will fit so called blue dots brake and all fittings will fit original wires they have only 2 abico connectors to fit
but be avare fjr cylinder is 16mm so you get very fast responce(ss brake lines in my bike) when you braking,and your front forks dont notice that.and
ilike to use fjr adjustable lever come with master.so fj original dont fit tested.
hope i text rigth, idont use any silly translator..
Let's review shall we....
The oem FJ m/c is a 5/8" dia. piston (16mm) You can see it cast 5/8 on the body.
Early 2003 FJR m/c's were 14mm...You can see it cast 14 on the body
All later FJR m/c's are 15mm.... You can see it cast 15 on the body.
I am not aware of any front brake FJR m/c's that are 16mm.
