Gallery Photos
Started by ogmudbone, March 13, 2009, 03:06:37 PM
ogmudbone
  Just put the pic of how they cut my ignition switch off the top triple clamp up. The guys at the junk yard told me how they do it. They take a pry bar and place it between the fork and frame and pry hard to bust the steering lock. Then they take a hack saw and just saw the lug off the top triple clamp that your ignition switch bolts to. Then they bust open the ignition switch, and on the inside is a plastic knob ironically key shaped. After its busted open that knob just turns freely. They are able to turn it on and off just like a key at this point.
   I just thought you all should know how this is done in order to hopefully protect yourselves better.
OGmudbone
What do you want to do with your life? I wanna rock!!!
