1tx owners help needed
Started by Hath87, December 24, 2016, 12:19:44 PM
Hath87
Please if possible can someone take a picture
Of their cdi unit please, namely the wiring going into it. Thank you so much .
FJ1100mjk
Mine might of been modded a little.
Iron Balls #00002175
www.ironballs.com
TexasDave
Being an electrician I can see several things wrong with that breaker panel but the main thing is I don't see a CDI anywhere inside that thing.
Dave
 :bad: The horrors of unskilled labor.....
Hath, if you download an Owners Handbook for your particular model FJ, (it's free) there is a color coded wiring diagram in the back of all handbooks that will show you what you need...
Lots of good info in the Owners Handbooks....see the link in my sig line.
Hath87
Appreciated pat, someone's been into the wiring and changed wires left right and centre  trying to get a grip on it wothout blowing another cdi unit up.
weymouth399
I'm sure I have everything you may need to fix that mess.
Bob w
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
The Haynes manual does a pretty good job with their wiring diagrams. I have not found a case where the colors do not match up....at least for my 3cv's.
In cas the colors did not come through well in the photo.the wire colors are as follows. Starting at the top
Connector 1,
Black
Orange
Grey
Connector 2,
Black w/white stripe
Black
Orange
Red w/white stripe
Grey
mr blackstock
There's also some diagram pictures in the files section: http://www.fjowners.com/index.php?topic=9216.0
Not sure if they are for the 1TX, but they are in colour...
Gareth
Yamaha FJ1100 1985
ct7088
Chris
ct7088
Well no picture
                 orange | grey
latch          black   | blank      front view harness connector
side                                      looking at pins
               red/white | black
               orange     | gray
           yellow/black | black/white     same view
Chris
