Lubing Hydraulic Seals
Started by Yamahammer1200, January 21, 2016, 10:12:54 PM
Yamahammer1200
Got my package from RPM with rebuild kits for the clutch slave and M/C.  Unsure on how to lube the pistons and rubber bits during reassembly.
I have heard everything from a heavy film of brake fluid, rubber grease to Silicone brake grease.
There was a packet of red grease that came with the OEM rear caliper seals.  I  put a thin film of that on the seals, piston and bore once they were thoroughly cleaned.  Seemed to work fine.
Was that Silicone grease?
Chrome don't get you home.
Yes, it is probably silicone grease.
I've always just used the same brake fluid I'm going to use in the system.
krusty
Use brake fluid only to pre lube brake piston seal. Use the silicon grease on all other moving parts.
84 FJ1100 x 2
85 FJ1100
89 GL1500
76 CB750F1
72 CB350F
63 C92 x 2
59 C76
62 C100
63 C100
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E x 2
79 DT250F
