GIVI knock-off mod
Started by aviationfred, October 19, 2015, 07:13:32 PM
I have been looking for the smoke lenses for my GIVI knock off top box. For those that don't know , RPM is a GIVI distributor and was able to order me a set of lenses. I did get the center brake light lens, but a little modification needs to be done before I can mount it. rpmracing.ca.com
The results are exactly what I was looking for.
This with the original red lenses.
The Smoke lenses installed.
With the running lights on.
With the brake light on.
markmartin
Nice work Fred.  I've got the same top box and was planning to install a brake light / running light on the center lens this winter.  What light set up did you use? Home made wire harness or something off the shelf??
Quote from: markmartin on October 19, 2015, 07:33:34 PM
I used LED light strips that I found on eBay and made my own wire harness to tie everything together. Simple spade connectors are used for a disconnect.
I like the connector that Alan used in his post. I may install a 3 pin weather proof connector over the winter.
Quote from: aviationfred on October 19, 2015, 07:47:56 PM
The same seller has 3-pin connectors as well.
http://www.ebay.com/itm/New-Delphi-Weather-Pack-3-Pin-Connector-Kit-12-GA-/331238755204?hash=item4d1f5e4b84:g:-EkAAOSwFTRTqd5C
They are pretty inexpensive.
