Thread size
Started by Flying Scotsman, April 12, 2015, 12:50:11 AM
Flying Scotsman
What is the thread size for the lower frame rail bolts.The 2 bolts on each side at the back of the frame rail.I know its M8 but was wondering if its a M8-1.25 thread in the frame.Anyone know the pitch.
1990 FJ1200
1999 GP1200 (165 + hp)
Pretty sure you're correct that its an M8-1.25
However, the hole in the rail is 10mm, and IMO the best way to stop these bolts from breaking or loosening is to drill and tap the threaded hole in the frame so that you can use 10mm bolts.
Flying Scotsman
Thank you Arnie.
Yes i know I can tap it bigger.
I already have a bag of M8 1.25 helicoils I use on my GP1200 cylinders if the frame is solid enough there I can pop a helicoil in there.Saves me looking for new bolts.
1990 FJ1200
Paul1965
Quote from: Flying Scotsman on April 12, 2015, 12:50:11 AM
Scott, you could always text me a pic of the bike where the bolt is and I'll pull one out of mine and measure it for you.
1978 Yamaha 400 Sold
1984 Yamaha Maxim 400 Blew up
1982 Yamaha Vision Sold
1983 Kawasaki GPz1100 Sold
1984 Yamaha FJ1100 Killed it
1991 Yamaha FJ1200 Sold
2009 Triumph Sprint ST Sold
2014 Triumph Trophy SE
Flying Scotsman
I can check when I get out to the garage in the next couple of days.
1990 FJ1200
Confirmed, M8-1.25 x 35MM, I took the bolt from this spot.
Then used the proper tools to measure"
Flying Scotsman
Awesome I have a bag of those have the drill tap and insert tool as well.
My 85 has 2 stripped on the left side.
1990 FJ1200
Look at getting grade 10.9 if you want to stay at M8x1.25 which is what I did on my '84
On my old '92 (now Paul Lawson's) and on Jason Lawson's '93 we replaced the M8's with M10's
2 of the M8's were sheared on the '92 and 3 (of the 4) were sheared on the '93.
