92 fj1200 but which one have i got?
Started by skik, February 12, 2014, 08:00:21 AM
skik
hi folks.when searching for parts for my bike i get about 4 different kinds of 92 fj's.ad,adc,d,dc.
mine has an abs light in dash so i take it that it has abs brakes.thats as much as i know.how can i tell which one i have?
It 'should' be on the vin plate on the headstock where its very difficult to see. :-/
The codes are really very simple, so you should be able to figure out which one you have  on your own.
The '92 FJ is the "D" model, those with ABS are "AD" unless they're designated as a California bike (meeting the CA emission regs) which will have that trailing C.
So, if your bike was 1st sold in California and does NOT have ABS, it is a FJDC
I'm only guessing but the 'C' models are probably California and the other designations are with and without ABS.  What's the VIN, we should be able to decipher from there...
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
skik
Quote from: Arnie on February 12, 2014, 08:37:47 AM
cant see all on headstock last 3 numbers are 387 but stamped on the frame at the top is 3XW 017387
o i live in the uk if that makes a difference
airheadPete
So, odds are it's not a California smog model. :mail1:
Do you have an ABS light on the dash, or wheel speed sensors inside the disks?
There, you're done! :good:
'92 FJ1200.    '84 R100CS
'78 GS750E.   '81 R100RS
'76 R90/6       '89 R100GS
'65 R60/2
Arnie is correct, my '89 is a FJ1200WC.
skik
Quote from: airheadPete on February 12, 2014, 12:40:30 PM
like in said in the first post.abs light on dash.also do you know if the front fenders [both halves] fit all years or do they differ?
Quote from: skik on February 12, 2014, 03:08:28 PM
Yes the front fender, (both halves) will fit all years of 1100/1200's
