Title: petcock turning tool Post by: gggGary on April 19, 2023, 06:12:21 AM A first version but it works! just some aluminum I had laying around.
I'm thinking if I do a mark2 it will have more of a U shaped handle. turning back up alongside the tank. Title: Re: petcock turning tool Post by: balky1 on May 08, 2023, 08:03:09 AM I don't get it, you need this for what?
Title: Re: petcock turning tool Post by: JPaganel on May 08, 2023, 09:41:47 AM I don't get it, you need this for what? I'm guessing it's for the 89 and newer petcock that the fuel pump models have. It has a square peg this would fit. Title: Re: petcock turning tool Post by: Waiex191 on May 08, 2023, 09:43:20 AM I use an open end wrench on my '89 petcock. Works great!
Title: Re: petcock turning tool Post by: Urx on May 08, 2023, 12:31:48 PM Yep 10mm spanner if i recall
Title: Re: petcock turning tool Post by: FJmonkey on May 08, 2023, 01:05:34 PM Yep 10mm spanner if i recall 10mm? I thought it was 8mm.Title: Re: petcock turning tool Post by: RPM - Robert on May 08, 2023, 01:17:42 PM It is indeed 8mm.
Title: Re: petcock turning tool Post by: Urx on May 08, 2023, 04:05:29 PM How can you tell its been ages since the tank was off my FJ LOL….YES 8mm open ender
Tank and fairing will be off over the next few weeks as i strip off an ancient and annoying alarm as well as fitting the new front end and powder coated fairing bracket. Depending how that mission goes i,may just plough into the swing arm swap as well…we shall see. Title: Re: petcock turning tool Post by: RPM - Robert on May 08, 2023, 04:15:51 PM Only the left side cover has to come off to access the petcock with the open end of a standard 8mm.
