Seems we have a lot of recurring questions on clutch slipping.
Check it out, hope I did not miss anything. This should help the new folks.
http://www.fjowners.com/index.php?topic=1808.msg14307#msg14307 (http://www.fjowners.com/index.php?topic=1808.msg14307#msg14307)
And it works! :yahoo:
Thank you sir!
:blush: I might have a stupid question... -but my momma says stupid is who stupid does- so here it goes.
How does it feel when the clutch is slipping?
I am having the hardest time changing gears, like getting neutral is nowhere there, and first also very hard like kicking it down and I feel like I am destroying the thing.
Is this a sign of the clutch been slippery? I was thinking maybe some of the joins and axels need some lube or so...
I did anyways buy a shifting Detent kit from RPM and will give it a go to install it, but I know I have to remove the clutch anyway, so if this is a clutch issue I could already kill two birds with one shot.
How can I differentiate if the shifting issue is not the clutch? I am starting a thread right now but thought to give it a try here just in case. not trying to hijack this thread at all...
Just thought it should be nice to have a clear image for us new to this what to acknowledge as clutch slipping problems.
Thank you very much.
Ser...
A slipping clutch is easy to test. Ride where you can accelerate hard safely. Perform WOT (Wide Open Throttle) pulls once you are in 3rd gear. A slipping clutch will allow the engine to spin up to higher revs quickly with no benefit of acceleration. Hard shifting may be a leaking clutch slave or air in the clutch hydraulics. This causes the clutch push rod to push less. This means the clutch plates are still dragging a bit so the gears still have load on them when you are shifting.
Test for clutch slip, then report back...
Thank You Pat.
You're welcome Cat, it was a group effort....
This is timely for me because I think my clutch is slipping at WOT and high RPMs. For now I'm just avoiding that bit of fun because 1) I want to get back to the airplane and 2) no problem keeping up with the V30 Magna.
Quote from: FJmonkey on June 09, 2019, 12:22:36 AM
It was a leaky slave cylinder, its been fixed now, thanks.
