General Category => Maintenance => Topic started by: Charlie-brm on August 06, 2013, 02:52:59 PM
Title: Ignition timing cover is cracked
Post by: Charlie-brm on August 06, 2013, 02:52:59 PM
Straight to the point, it is cracked across the face from 4 o'clock to 6 o'clock and all the way back through its thickness along the bottom rim.
There is a small amount of oil accumulated there but maybe that is blown back there from somewhere else forward of the cover.
(http://i1296.photobucket.com/albums/ag17/Charliebrm/Forum%20images/FJ1100OilPumpCoverparts_zps5bcb9fd2.jpg)
Yamaha microfiche calls this the oil pump cover but it is the ignition timing cover, right?
I haven't taken it off but it seems to be made of plastic, not die cast metal.  Would a clean prep and JB Weld or similar keep this from getting worse?
Other suggestions? I see them online rarely and the price is over $100 and I don't see the rubber ring gasket included in that.
Title: Re: Ignition timing cover is cracked
Post by: racerrad8 on August 06, 2013, 03:06:11 PM
There should be no oil present behind the cover unless the crank seal is leaking.
It is aluminum and not plastic.
The gasket is not included, nor are the bolts.
I have several good used ones that I removed from the race cars.
Shoot me an email if you want a used one; randy@rpmacingca.com
Post by: DarthLoser on September 03, 2013, 04:47:47 PM
I bought one a couple weeks ago, installed it yesterday and it looks great.
Thanks Randy!!!  :good2: :good:
