General Category => Maintenance => Topic started by: eeshed on June 27, 2013, 01:23:55 PM
Title: Leaking petcock, o-ring will not seal
Post by: eeshed on June 27, 2013, 01:23:55 PM
Dear community,
My 1985 FJ1100 has a fuel leak from the petcock. I think the leak comes from the o-ring fitting of the pipe that comes out of the shut-off.  When I shut off the petcock the leak stops. Any ideas how to fix that? My mechanic suggested: a) find a used replacement petcock. b) find a brass threaded nipple, and tapper thread the petcock to fit the nipple.
Does any one have experience with fixing this problem? Any suggestions?
Best regards,
E
Title: Re: Leaking petcock, o-ring will not seal
Post by: Dads_FJ on June 27, 2013, 03:15:08 PM
A used one will probably have issues as well.  I would recommend a new one.  http://rpmracingca.com/proddetail.asp?prod=M%2FC%3A84-85Petcock (http://rpmracingca.com/proddetail.asp?prod=M%2FC%3A84-85Petcock)
Post by: fintip on June 27, 2013, 04:43:05 PM
My solution to this problem ('86, so similar enough) was to put a small rubber 'washer' that I found at a local hardware store behind the spring. First I replaced the plunger o-ring, of course, but that didn't fix my problem. No leak after shimming the spring, though!
However, I shortly thereafter developed the 'failing vacuum' 'monkey-itis' syndrom, where my petcock
1. Will not deliver enough fuel if I ride at 120 mph for extended jaunts (not a huge problem)
2. Will not deliver enough fuel if the tank has less than 1.5-2 gallons in it (kind of a pain, but I've been living with it like this for months now, just refill  at the 125 mile mark on my trip meter to be safe).
The knowledge I've collected on petcocks so far is here, though the page still has room for improvement: fjowners.wikidot.com/petcock
By the way: what would threading a brass nipple onto your petcock help with? ???
Post by: fj11.5 on June 27, 2013, 04:47:25 PM
I think he,s saying its leaking at the outlet joint,  where the arm pushes into the petcock body
Post by: Dan Filetti on June 27, 2013, 05:04:45 PM
Quote from: fj11.5 on June 27, 2013, 04:47:25 PM
If so, put a twist-tie on it!  It can and will come loose, and spray gas on your hot motor.  This then will burn your FJ (and perhaps the house over it) to the ground, I know this from experience -not the house bit...  My advice: DO THIS NOW, WITHOUT DELAY -BEFORE YOU RIDE AGAIN.
Post by: fj11.5 on June 27, 2013, 05:26:20 PM
Dan knows the effect all to well if that fitting fails  :shok:,, fix it from leaking, then as dan said tie it,jb weld it,  silastic it if you have to,  just don't leave it to fall out
Post by: fintip on June 27, 2013, 05:34:08 PM
I just thoroughly revised the petcock page, so it is a rather complete source of information (including the aforementioned safety subjects). Feel free to check it out.  :music:
Post by: mr blackstock on June 27, 2013, 05:37:26 PM
I had the same problem with my FJ1100 '85.  Best solution I found was to coat the elbow in petrol resistant sealant, easy to buy from a local auto store, and wired up the elbow to the petcock with wire.
Been a few years and not a single drop has leaked out.
cheers, Gareth
Post by: RichBaker on June 28, 2013, 12:06:31 AM
I'd use some penetrating (green) Loctite 290 (http://www.loctite.co.uk/fullproduct-list-loctite-4995.htm?redDotUID=1000000IA9V#a)..... It will penetrate and seal.  I've used it in oil environments and it works well. Don't see anything about gas, but I bet it isn't affected.
Assuming it IS the tube, and not the o-ring.
Post by: eeshed on June 29, 2013, 08:28:56 AM
Thank you all. Based on the great feedback I will do ASAP the follow : seal the tube with the locktite and wire. If problem is solved that's great. Second option, contact RPM and buy a unit. Third, in Woodstock Ontario a cycle wrecker just got FJ1100 for parts. I may get the petcok from the wrecker and explore a rebuild.
Eyal
Post by: Tiger on June 29, 2013, 02:16:36 PM
Quote from: eeshed on June 29, 2013, 08:28:56 AM
.... in Woodstock Ontario
:hi: Hi and welcome...where abouts in Ontariario are you?? I'm actually meeting with a new FJ'er, from Sarnia, in Woodstock tomorrow (Sunday) for a coffe at Timmies (10 a.m.) if you care to join us :good:
BTW, I'm from Erin Ontario...
John.
Post by: eeshed on June 30, 2013, 06:35:59 AM
Hi John,
I'm in Burlington, may be in WS later this afternoon. Please send me your contact info to eyal@eshed.ca. We can try to work something out.
I am baffled by the fuel shut off. I disassembled it yesterday to clean and rebuild the leaky elbow pipe. I bored a 1/4 pipe thread and replaced the elbow with a 3/8 Barb 1/4 PIT brass Male Threaded Adapter. Got it at Home Depot for under $5 off the shelf. The Tapper thread I had to get from Low's. This fixed the fuel leak from the compression pipe. ! However, the fuel will not flow when the valve is on On position.
There are two positions for the valve; "On" and "Pri". When I put the valve on "On" the fuel doesn't flow at all, even when the engine is running and the vacuum hose is attached. When I put the valve on "Pri" the fuel flows freely even when engine is off.
I don't have the owner's manual and I don't know how the petcock should function. What should be the proper operation of the valve? When to use "Pri" and when to use "On"? What may be not working? Can I rebuild the petcock to function properly?
Eyal
Post by: FJmonkey on June 30, 2013, 10:24:46 AM
Quote from: eeshed on June 30, 2013, 06:35:59 AM
Eyal
Eyal, when the valve is set to "ON" it requires vacuum, not a lot but some for fuel to flow. A nice safety feature to stop fuel from flowing when the engine is off. It can be duplicated and or tested by sucking on it. With all but the vacuum line connected, suck on it. A good valve will act like a straw that is plugged and not allow any air in. A leaking valve will allow you keep sucking to maintain vacuum. If air is leaking then you will have fuel delivery issues. It took me a while to figure this out on my 27 year old petcock. So suck on your petcock and tell us what you think.....
Post by: eeshed on June 30, 2013, 03:25:31 PM
Thanks. I will test for vacuum. Can I still ride with the petcock set to Pri?
Eyal
Post by: fintip on June 30, 2013, 03:31:48 PM
Quote
I see what you did there...
Eyal:
You can, but it's a risk--the only thing stopping your tank from gushing out gas onto your engine when the bike is stopped will be the needles and seats in the carbs, and those aren't really the most reliable at performing that job (they are made to have a petcock doing most of that work, it seems). Ideally you should turn it off of prime every time you stop the bike, but it's a pain to access, so... That's lame.
You can install an in-line manual on/off switch. Or an inline vacuum switch, essentially replicating the original function of the petcock.
It will be easy to overflow the carbs if left on prime, however, and you also risk a fire (though the risk of fire in this particular case isn't as great as from the press-fitted piece).
tl;dr: Yes, you can, but it's risky. Be careful. Would be best if you turned it off of prime when stopped, sadly that's a pain.
Post by: FJmonkey on June 30, 2013, 03:39:07 PM
As Kyle stated, it is taking a risk to leave the petcock in the "PRI" while you are not riding, parked. If you need it to get from point A to point B then it should not be a problem. While I was having fuel delivery issues and stalled by the road side I pulled the seat and side panel and switched to "PRI" to see if that helped. But when I got home I switched it back to shut off any unplanned fuel flow. A bit of a pain to do if you need you bike for commuting, but it can be done till you fix the issue.
Post by: eeshed on June 30, 2013, 04:58:01 PM
I think I found the reason for the leaking. It is the o-ring seal that seals the turning dial. When the dial is on Pri there is no leak. When the knob is at On the fuel leaks from the shut off. My vacuum shut-off looks like working ok.
Any idea where I could get this seal?
Eyal
Post by: fintip on June 30, 2013, 05:28:47 PM
 :diablo:
THERE IS NO REBUILD KIT! MWAHAHAHA.
The '86 doesn't have a turnable dial, so I don't know if your piece is a custom shaped rubber piece like most have or just on O ring.
If it's an O ring, try a hardware store with the petcock and the old one in tow.
If it's a custom shaped piece... I know a guy once took a tire inner tube and very carefully cut out a replica. Gave him faithful service until last I checked. YMMV. Go see the video on the petcock page I list, http://fjowners.wikidot.com/petcock, (http://fjowners.wikidot.com/petcock,) and watch the video to get an idea of the innards and the process.
Post by: RichBaker on July 02, 2013, 10:06:51 PM
There is a Kawi petcock rebuild kit that works, I don't recall the bike or PN. Might find it searching this site, maybe in the files section....
Post by: rktmanfj on July 02, 2013, 10:16:20 PM
http://www.amazon.co.uk/car-motorbike/dp/B005YEPH3M (http://www.amazon.co.uk/car-motorbike/dp/B005YEPH3M)
Post by: fintip on July 03, 2013, 09:41:57 AM
Interesting, but who is this?
The pictures are of generic petcock rebuild kits. None of them looks right to me.
I'm tempted to try it myself.
The kawa part numbers for spring and O-ring are listed on the wikidot (http://www.fjowners.wikidot.com/petcock (http://www.fjowners.wikidot.com/petcock)).
