With the BMW rear shock mod raising the rear of the bike. The sidestand was way short and taking a lot of weight. I made a sidestand foot extention using posts from this site for the rough idea. I modified mine slightly from the main mod post. I also added my luggage back on, mainly to check the muffler to bag clearance.
(http://i119.photobucket.com/albums/o145/aviationfred/IMAG0220_zpsaba1491a.jpg) (http://s119.photobucket.com/user/aviationfred/media/IMAG0220_zpsaba1491a.jpg.html)
(http://i119.photobucket.com/albums/o145/aviationfred/IMAG0219_zpsea75e9b9.jpg) (http://s119.photobucket.com/user/aviationfred/media/IMAG0219_zpsea75e9b9.jpg.html)
(http://i119.photobucket.com/albums/o145/aviationfred/IMAG0221-1_zps52d1a3a5.jpg) (http://s119.photobucket.com/user/aviationfred/media/IMAG0221-1_zps52d1a3a5.jpg.html)
(http://i119.photobucket.com/albums/o145/aviationfred/IMAG0222_zps41099e2e.jpg) (http://s119.photobucket.com/user/aviationfred/media/IMAG0222_zps41099e2e.jpg.html)
Fred,
If you paint that extension black, no one will notice it :-)
Also, you do realize that the luggage to muffler distance is not affected by the change of shock/links/wheel size, right? Its all fixed to the frame and subframe which hasn't been altered.
BTW Looking good
Arnie,
Yes, I know there shock didn't have anything to do with the pipe and bag clearance. Sorry, I didn't mention the change in the exhaust. When the bike went down for the head rebuild. I had a different pipe on it. When I got the bike back, the muffler was positioned in a way that was much to high for the bags to work. I saw a photo of Pat Conlon's 89' with the same pipe. His looked much lower and would work with the bags. I found out that the muffler is able to rotate a bit and gave me the clearance that I needed.
The before and after adjustment photos.
(http://i119.photobucket.com/albums/o145/aviationfred/IMAG0215_zpsd9b8e798.jpg) (http://s119.photobucket.com/user/aviationfred/media/IMAG0215_zpsd9b8e798.jpg.html)
I did mine the same way Fred. After experimenting with different height blocks under it in the garage for months, I settled on a height that was perfect, until I used it in the real world, too upright. It took two more adjustments to get it right. I thought this might happen so made mine from a number of plates, like shims, so I just had to unscrew it and remove one at a time until I was happy.
(http://farm8.staticflickr.com/7390/9011732791_b0fd584c51_c.jpg)
Thanks for the reminder, meant to sort the side stand on effie months ago, center was easy, just tacked on some large washers till she sat high enough, , I like your idea noel, better than making up half a dozen blocks
