General Category => Modifications => Topic started by: Antonn3 on May 25, 2013, 02:24:18 AM
Title: Suzuki rear axle torque spec?
Post by: Antonn3 on May 25, 2013, 02:24:18 AM
Hello, what is the torque spec for the GSXR rear axle please?
Thank you,
Tony
Title: Re: Suzuki rear axle torque spec?
Post by: movenon on May 25, 2013, 07:33:24 AM
Quote from: Antonn3 on May 25, 2013, 02:24:18 AM
Thank you,
Tony
Are you talking about a GSXR rear wheel conversion to a FJ ? If so you should be using a stock FJ axle in the wheel and the TQ for that on the FJ swing arm is 110 ft lb's. Hope it helps :).
Post by: chixson on May 25, 2013, 09:27:17 AM
I have a question on the torque setting...  should you use the settings for the Fj swing arm or the setting for the GSXR bearings?
Post by: movenon on May 25, 2013, 11:28:50 AM
Quote from: chixson on May 25, 2013, 09:27:17 AM
I TQ my GSXR conversion,  axle nut to 110 ft lb.  :good2:
Post by: FJmonkey on May 25, 2013, 08:04:52 PM
Nice save there George...
Post by: Antonn3 on May 25, 2013, 10:21:43 PM
Thanks George, yes it is a FJ axle.. should I not be concerned more about the compression on the Suzuki rim/bearing and spacer instead of the FJ spec?
BTW I have managed to fit a Suzuki 5.5 inch rim with the FJ axle, into an FZ1 swing arm ;)
Tony
Post by: FJmonkey on May 25, 2013, 10:26:38 PM
Quote from: Antonn3 on May 25, 2013, 10:21:43 PM
Tony
Cool, write it up so we can see what you did...
