General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: DreadRock on May 04, 2013, 10:01:07 AM
Title: 85 FJ clutch problem ......
Post by: DreadRock on May 04, 2013, 10:01:07 AM
  Need some help as im going on a trip in two weeks on my FJ maybe ? Bike was running great till other day and the clutch stoped engageing and limped it home ! So I worked on bleecing the clutch and got nothing . Tried everything I know and can get it to pump up ! I pulled the slave off to have a look and pulled the lever and piston seemed to push out fine but when I put it back on fluid moves thru it thru it but actes like there not enough pressure to disengage the clutch and seems like there is a lot of air in it ! Its not the first time ive messed with somethinig like this but im lost ???? Is there a trick im missing on the FJs or something im over looking ? Befor I start rebuilding or replacing would like to get a idea where to start !!!!
Any help would be great and thanks for the help !
Title: Re: 85 FJ clutch problem ......
Post by: movenon on May 04, 2013, 10:49:54 AM
From what you said I would rebuild the clutch slave first. They take a lot of patience to bleed. Did you notice any fluid leaking from the slave ? Any leakage around the master ? RPM has new seals . Easy to rebuild.
Post by: DreadRock on May 04, 2013, 11:23:48 AM
No nothing leaking that I can see around either but I will look again today ! Is rebuilding the slave the same deal as rebuilding a caliper ? yea I looked at RPM really really nice guy first place I looked !!! Ill give the bleeding another go and if nothing works will get ahold of RPM Monday !
Post by: racerrad8 on May 04, 2013, 12:43:55 PM
Quote from: DreadRock on May 04, 2013, 11:23:48 AM
...and if nothing works will get ahold of RPM Monday !
If you have to reach me, email is going to be the best way followed by PM.
Bump in the road... (http://www.fjowners.com/index.php?topic=8950.0)
randy@rpmracingca.com
Post by: hein on May 04, 2013, 12:53:08 PM
Please clarify your problem. You first state that the clutch will not engage,  indicating a slipping clutch, then you say it will not disengage which would mean a problem with either the master or slave cylinder. These are two different problems.
Hein.
Post by: markmartin on May 04, 2013, 02:47:41 PM
Quote from: DreadRock on May 04, 2013, 10:01:07 AM
 >> <<...the clutch and seems like there is a lot of air in it ! Its not the first time Ive messed with something like this but I'm lost ???? Is there a trick im missing on the FJs or something im over looking ? Befor I start rebuilding or replacing would like to get a idea where to start !!!!
Hein's got a good point, but if it is your slave or just a bleeding problem, I got this method from this forum and used it last time I serviced my slave when a regular bleed wasn't working.
Get a syringe and a length of tubing, put the tubing onto the bleeder valve, open the bleeder valve and inject as much fluid as you can into the slave and line.  You'll have the diaphragm out of the master cylinder and the cover just sitting on the  M.C. housing.
I'm not sure if this next step is required, but I then tie my clutch lever to the bar, and leave it overnight to allow any air bubbles to migrate up and out.  I'll tap and wiggle on the lines every so often to help any trapped air move along.
Bleed it conventionally again in the morning  and then close everything up.
If your clutch works for a while (a day) and then starts to fade again, I'd change the seals on the slave piston.  It's not hard to do and the rebuild kit is only about $17.   "Rebuild" is a strong word here, it's just changing out 3 rubber parts and a spring.
Size comparison standard brought to you by the fine folks at the Miller Brewing Company
(http://fjowners.com/gallery/4/150_04_05_13_1_31_38.jpeg)
Post by: Dan Filetti on May 04, 2013, 09:50:17 PM
I recently saw such a syringe at, of all places, Tractor Supply Store...
FYI.
Post by: FJmonkey on May 04, 2013, 10:28:29 PM
Quote from: Dan Filetti on May 04, 2013, 09:50:17 PM
FYI.
And what pray tell....were you doing in a tractor supply store??? Needing parts for your bike???  :rofl2: :rofl2: :rofl2: I could not help myself....
Post by: movenon on May 04, 2013, 11:46:33 PM
FYI.
That's where I get them also.....
Post by: Woodsman on May 05, 2013, 01:13:45 AM
FYI.
[Get them at the local vets myself.
Sean/quote]
Post by: oz.fj on May 05, 2013, 04:40:17 AM
The local saddlery for me :pardon:
Darran
Post by: DreadRock on May 08, 2013, 10:38:49 AM
Thanks for the help guys !
   After reading what I wrote I did kind of miss wrote things so I try again .
  The clutch would not disengage and when I tried to bleed it after limping it home the lever would not pump up . I pulled the slave off and when I pumped the lever the piston would move out but as soon as I placed it on the bike it wouldn't pump up and air just keep coming out of the bleeder after a few hours of pumping it . Did some reading and talked to a few guys that know more then I and it always came down to the slave !
   Im heading down to KY for a DTT GTG and really want to take the FJ as my CafĂ© build is not all the way done .
I took a shot and called RPM and couldn't wait so jumped on his site and ordered a rebuild kit . I cant say enough good things about Randy ( think that's it ) as its on it way and hope this will fix it . Again guys thank you so much for the help and a few laughs LOL
  Will let you know if its a fix !!!
Post by: Thmsdoyle on May 08, 2013, 11:17:11 AM
I had the same issue this spring, rebuilt the slave. Had to bleed the line a few times, seemed like it took a while for the air work ts way out of trapped areas. Some here say they wrap the clutch line with a screw driver handle to help the air bubbles move. Sounds like your headed in the right direction. What part of Ohio are in. I get into Ohio frequently to see family. And always looking for good rides.
Post by: DreadRock on May 08, 2013, 09:44:09 PM
Akron / canton area !
Post by: Thmsdoyle on May 08, 2013, 09:47:20 PM
Our family is in the Columbus area, I do further north sometimes.
Post by: DreadRock on May 10, 2013, 08:00:12 AM
Mid-ohio vintage is a good time if you make it there at the end of july well worth the time ! And I rebuild the slave last night and bleed it then wraped the lever back and let it set over night . Got up befor work today and messed with for a few min then wraped the lever back down till I get home . I have 2 master cylinders I can use if need be which I might switch out just to be safe !!! Will let you guys know what happens !!!
Post by: DreadRock on May 12, 2013, 09:14:56 AM
 :yahoo:
  Lets see I rebuild the slave cylinder and that didn't fix it so only thing that was left was a master . Well didn't have time or money to pick up a rebuild now for that . Well made a few calls to some friends and found a good master off a ( cough cough ) honda ! Well worked on it and still couldn't get to bleed so on the phone I went again same friend has a mightyvac and that fixed it  :good2:  Now I have to ask where do I get one of those LOL
Thanks for all the help guys !!!
Post by: Mike 86 in San Dimas on May 12, 2013, 06:40:53 PM
Alright! Happy ending. The mighty vac can be found at an auto parts store.
Post by: Dan Filetti on May 13, 2013, 07:02:00 AM
Quote from: Mike 86 in San Dimas on May 12, 2013, 06:40:53 PM
Never thought of using it that way, but hey man, if that's your thing... :)
Post by: DreadRock on May 21, 2013, 10:27:17 AM
Just wanted to say thanks again for your guys help ! My trip to RRG in KY was a great time . We did about 800+ miles over the weekend with no problem.....
(http://i1104.photobucket.com/albums/h331/dreadrock1/thaw9_zpsa1f572a9.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/thaw9_zpsa1f572a9.jpg.html)
Post by: rktmanfj on May 21, 2013, 12:31:33 PM
Quote from: DreadRock on May 21, 2013, 10:27:17 AM
I rode through that tunnel a few years ago... pretty cool.    :good:
Post by: Jeraldo on May 21, 2013, 02:13:56 PM
Quote from: DreadRock on May 08, 2013, 10:38:49 AM
I had the same problem last year -- slave rebuild completely did the trick.
BTW, I found this in the old Yahoo group for FJ1100/1200s:
Yes [slave cylinder rebuild kits] are available. You can get them from Yamaha and aftermarket
manufacturers like K&L also make them. A rebuilt kit (a new o-ring and a new
dust boot) should cost you around $15-$18. The slave is pretty easy to rebuild,
but they can be a hassle to bleed. Most people have have good luck reverse
bleeding the system. That is, pushing the fluid up from the slave to the master
instead of the other way around. I personally use a large syringe to push the
fluid up, I then draw it back down, then push it back up. I repeat this until I
don't get any more bubbles (put Teflon tape on the bleeder screw threads to
avoid air leaking in or fluid leaking out). If you do decide to reverse bleed,
push the fluid extremely slowly or it will "shoot" out of the master cylinder
and make a mess (keep a wet towel handy).
Jerry
