General Category => General Discussion => What did you do to your FJ today? => Topic started by: big r on April 14, 2013, 04:32:20 PM
Title: spring start up
Post by: big r on April 14, 2013, 04:32:20 PM
Hauled the bike out of the shed yesterday. Put the new clutch and brake lines on and bled them. Boy is the mighty vac ever make it easy. New speedo cable, couple of grommets in the valve cover. Can any one tell me which wires are the tach wires from the coil, I cleaned some to try and get my tach to work properly but I must not have found the right ones. It will only show revs to about 300 or so. Could there be a problem with tach itself. Also what is the best type of fuel line to use, mine is getting kind of hard and brittle. Also can someone tell me how the signal lites are attached to the front fairing, mine are kind of loose in the fairing. Can't wait for the weather to get better so I can get out there and feel the kookaloo again. Thanks for any and all help Big R
