General Category => Maintenance => Topic started by: HARTLESS on March 20, 2013, 11:19:32 AM
Title: What size front tire should I run?
Post by: HARTLESS on March 20, 2013, 11:19:32 AM
120/70/17 or 120/70/17. Found a couple 120/65/17s too. Had 60s on it
And it was fine. Just wanted to know your thoughts as I am getting a new one
Title: Re: What size front tire should I run?
Post by: rktmanfj on March 20, 2013, 11:34:34 AM
Quote from: HARTLESS on March 20, 2013, 11:19:32 AM
I'd get the 120/70/17.
Post by: Pat Conlon on March 20, 2013, 11:38:30 AM
120/70-17 is what most of us run, if you have the 3.5" wide front rim, you can run the smaller diameter 120/65 but not on the oem 3.0" rim. With the shorter sidewall you need the wider rim.
Your speedo will run higher with the 120/65 and turn in will be quicker.
Hope this helps.  Pat
Post by: movenon on March 20, 2013, 12:22:13 PM
I don't know if it is right or wrong but I have 120 60 17 on a 3.5. rim.  The PO had the 120 60 on the old 3 inch rim. And it
seemed to be OK, but I am more of a cruzer type rider. I get dizzy just seeing the yellow line and the edge of the road.  :unknown:
Maybe the speedo running higher will off set the rear 180 55 17... ? Or at my age the illusion of going faster will be welcome :lol:
Post by: HARTLESS on March 20, 2013, 12:26:08 PM
Sweet, I figured just go back to stock. I'm no racer either, plus I like to know how fast I'm really going
Post by: yamaha fj rider on March 20, 2013, 01:02:53 PM
Check with the tire manufacturer they have recommendations for correct size for your rim size. Avon had me use the 110/70-17. Hope this helps.
Kurt
