General Category => Modifications => Topic started by: 93fj1200 on November 27, 2012, 07:14:49 PM
Title: GSX-R wheel swap shims
Post by: 93fj1200 on November 27, 2012, 07:14:49 PM
Would like to know the thicknesses of the shim(s) that people used on each side of the wheel, sprocket side and brake side?
Title: Re: GSX-R wheel swap shims
Post by: Arnie on November 27, 2012, 07:37:59 PM
The shim thickness can vary depending on exactly which GSXR wheel/sprocket drive/brake hanger you are changing to.
Measure the distance not taken up by the wheel assembly and divide by 2.
This will give you the thickness of shim needed.
Post by: markmartin on November 27, 2012, 07:53:26 PM
This is what I did.  Probably more work and unneeded fussing on the spacing. Others have spaced theirs equally on each side and I've heard no complaints.
I was as concerned about getting the sprokets to line up.
http://www.fjowners.com/index.php?topic=6220.msg55216#msg55216 (http://www.fjowners.com/index.php?topic=6220.msg55216#msg55216)
