I just know that somewhere, in the last couple of weeks, I saw a text list of standard automotive oil filters that can be used in place of the OEM unit for those who haven't (yet) gone for the spin-on adapter.
Not the all-bikes list that's copied in several places; it only lists the Fram CH6006. This is an FJ-only list that has about a dozen different manufacturers and part nos.
I should have saved it when I saw it, but I didn't.
I thought it was here or in the Yahoo group files section, but now when I want it, I couldn't find it to save my life!
I'm sure somebody must have saved it or remember where it is... could you please post a copy or a link or something?
TIA,
threejagsteve
AFAIK, there are no Automotive filters that replace the OEM FJ filter. The auto filters only apply to the spin-on adapter.
DaviDR.
You can also use a CH6012 as the filter is the same, but the o-rings are different. The CH6012 fits the Ninja 250.
See my listing in Parts Available.
David,
There is a car filter that's virtually identical to the Yamaha unit; I used to use them all the time. But after 6 years of not riding, I can't remember which one it was. It's for an '80s Honda (car) 4-banger or something ubiquitous like that. It used to cost $2-3 at the auto parts. 'Course you don't get any o-rings, but I've found that you really don't need to replace the o-rings with every filter change anyway.
Thanks, pdxfj. I'll keep that in mind.
Quote from: FJmonkey on August 21, 2009, 06:20:11 PM
http://fjowners.com/index.php?topic=770.0;topicseen (http://fjowners.com/index.php?topic=770.0;topicseen)
Thanks, Mark!
Quote from: threejagsteve on August 22, 2009, 02:58:59 AM
David,
Wow, I never knew this! Be sure and post when you find out.
Here is the list that was in the Yahoo Database. When I get a few minutes I will put it in the files.
BIG A 96937
CARQUEST 89937
CHAMP, WARNER, LUBER-FINER P7006
FRAM CH6006
HASTINGS LF569
Hi-Flow HF-401
K & N KN-401
NAPA GOLD 4937
PUROLATOR ML16806
STP MSO06 (Emm Ess Oh Zero Six)
WIX 24937
zNOTE: Thanks to Tim Mintz for this info.
So it was there!
I looked everywhere (or so I thought)... where'd you find it?
I guess that's why you're the Files Section Guru! ;)
Quote from: the fan on August 26, 2009, 02:14:27 PM
BIG A 96937
CARQUEST 89937
FRAM CH6006
HASTINGS LF569
Hi-Flow HF-401
K & N KN-401
NAPA GOLD 4937
PUROLATOR ML16806
WIX 24937
Tried several searches, got either too many hits to be useful, or only one--this one.
Multiple on-line sources are saying that either the Wix/NAPA oil filter 24937/4937 or the 24940/4940 will work in an '86 FJ1200. Dimensions that I can find are similar but not identical. (I can't find a dimension for the center hole)
I've got a few of the 4940 filters on the shelf, they fit my CB1100F. Am I safe using them in the FJ1200 I bought last night?
Wix changed the 24937 a couple of years ago and it will not longer fit the FJ1200. I would not recommend using any of them marked with that series of numbers.
I stock the genuine Yamaha or Stainless steel FLO filter.
OEM Yamaha Cartridge Oil Filter (http://www.rpmracingca.com/proddetail.asp?prod=36Y-13441-00)
FLO Stainless Steel Canister Filter (http://www.rpmracingca.com/proddetail.asp?prod=FLOCanister)
Or now might be the best time to update to the RPM Spin On Oil Filter Adapter (http://www.rpmracingca.com/proddetail.asp?prod=spinonfilteradapter)
The Spin-On oil filter adapter is the Gate-Way drug to Moditus. My first mod and I love it. No more pinched wires, O-Rings, thin metal washer, just spin-off the old and spin-on the new.
