Well i finally got tired of not be able to adjust my headlight so i took off the cowling and removed the headlight and the adjustment. i looked around and found a 1/4" swivel adapter so i cut off the male end and drilled a hole in it for the adjustor and then drilled a hole in the other end for the roll-pin. Put it back together and it works great.
(http://fjowners.com/gallery/3/1801_25_09_12_8_09_42.jpeg)
Very nice solution...
Looks great way to go.
Kurt
Why do I find this now. I threw away my headlight adjuster the other day. :ireful:
you threw an Fj part away :shok:, , that's 100 lashes and transportation to van deamons land :biggrin:
Quote from: ELIMINATOR on October 02, 2012, 03:41:19 PM
I have a second one that needs this fix. I had the option to fab up the broken part.
http://www.fjowners.com/index.php?topic=6838.msg63877#msg63877 (http://www.fjowners.com/index.php?topic=6838.msg63877#msg63877)
Scroll up till you see my OEM looking fix in SST.
Score on eBay - I think I am starting to become a FJ NOS part horder.....
https://media.fotki.com/2v2uhbVnFxANksL.jpg
Electrical Heat Shrink wrap it with grease in it for lubrication. No chance of it falling apart then
