General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: Mark on September 18, 2012, 03:39:46 AM
Title: oil leak
Post by: Mark on September 18, 2012, 03:39:46 AM
[img]http://fjowners.com/gallery/3/medium_2724_18_09_12_2_25_57.jpeg[img]
fired up the project fj today and irs got 2 oil leaks frombetween crankcases adjacent to front engine mounts,i had a lot of pressure in this area freeing up the mount pins.anyone seen this before i assume motor out and split cases to sort it out,also can anyone tell me where this bracket belong, many thanks
Title: Re:bracket
Post by: Mark on September 18, 2012, 04:16:18 AM
(http://fjowners.com/gallery/3/2724_18_09_12_2_25_57.jpeg)
Title: Re: oil leak
Post by: racerrad8 on September 18, 2012, 07:59:43 AM
Oil cooler line mounting bracket
Title: Re: oil leak
Post by: Mark on September 18, 2012, 04:11:17 PM
Thanks for the info on bracket Randy,did you see my post about oil leaking from between crankcases on both sides near front engine mounts, any ideas what I can do here, would splitting the cases and using some type of sealant on surfaces work,prob should have split it and replaced bearings to start with anyway.thanks again
