i've been building a turbo fj1200 chop (in the writeups)
i've got to the stage of trying to get it to fire up,
i wired up the bike to the below plans and im pretty sure i screwed my ignitor
(http://www.haleyracingclub.com/images/Legends_color_wiring_diagram.jpg)
i had everything connected as per above exept the live to ignitor and live to coils which i connected last, it shorted out and if you do it again it does nothing. something is screwed. :dash2:
i have 3 wires from my timing pickup, can someone tell me what they all are?
its a 3xw motor and a 3cv ignitor.
do i need any resistors or something, am i missing something stupid?
i have pickup from the timing cover, 2 coils, one ignitor. (no boost advance)
someone please help me as the tension of not being able to start my bike is killing me!!!
Quote from: backstreetheros on September 06, 2012, 09:02:20 AM
Okay, if your CDI does not have the vacuum tube protruding from the box then you cannot use the dual (three wire) pick-up coil, you must use the single (two wire) pick-up coil.
Keep in mind you must also use the correct rotor for each style pick-up coil.
The wiring diagram I posted was for the 89+ version of the ignition system.
i dont know if this is related but on the rotor arm it says 1TN
i should have really taken a picture while i had it apart.
im looking for another ignitor now with this boost pipe on it...
then we'll try again :dash2:
