General Category => Maintenance => Topic started by: johnnyalpha on August 03, 2012, 09:50:49 AM
Title: Oil sight glass replacement ?
Post by: johnnyalpha on August 03, 2012, 09:50:49 AM
Hi, sorry I placed this in the wrong section earlier :/
here goes again;
Hi Folks, YamahaFJ1200 3xw, and I am is Edinburgh, Scotland.
I have recently noticed a weep of oil from the oil level sight glass, hope to change it before it "pops" and I end up in a world of pain.
I ordered a new seal from "Yambits" here in the UK.
Now I ambled out to look at the offending part a few minutes ago, and the window isn't "round", so I am guessing that the seal has be fitted into the "inside" of the case, am I correct ?
Any advice, experience gratefully received.
Ride Safe Johnny
Title: Re: Oil sight glass replacement ?
Post by: racerrad8 on August 03, 2012, 09:55:01 AM
Yes, it presses in from the back side of the clutch cover.
Post by: johnnyalpha on August 03, 2012, 10:00:55 AM
Ah excellent, thanks for that swift reply :)  MMMhh now I am wondering if I can "seal" the clutch cover back up ? or will I need a gasket Don't want to buy a complete gasket set, I'm not tight with money, just "careful". :).
Ride safe all
Johnny
Post by: racerrad8 on August 03, 2012, 10:06:30 AM
Quote from: johnnyalpha on August 03, 2012, 10:00:55 AM
Ride safe all
Johnny
You will need a clutch gasket as it will probably tear.
You do not need to buy a complete gasket set, you can find it here; Clutch Cover Gasket (http://www.rpmracingca.com/proddetail.asp?prod=Engine%3ACOMEC018020)
You can lean the bike over on the side stand and you will not lose much oil if any as well.
Post by: johnnyalpha on August 03, 2012, 11:16:36 AM
Cheers :)
mmmhh I'm in Scotland though, it's a long way Randy :)
Johnny
Post by: fj11.5 on August 03, 2012, 04:06:16 PM
you could buy the gasket cheaper and have it sooner from randy  and still be cheaper than your local stealership  :good2:, , be warned rpm is addictive  only cure is rpm  :dash1:  :wacko3:
Post by: johnnyalpha on August 04, 2012, 05:19:37 AM
Indeed, huge respect for RPM, I have bought from them in the past, and they were well priced and swiftly delivered :)  However, as I have the sight glass in my sweaty wee hand, I have opted for a local source of gasket, purely so I can get the job done on my next days off. :)
Post by: fj11.5 on August 04, 2012, 05:31:56 AM
cant argue with that mate, a man needs his bike  :good2:
