Hi,
I just parked my bike and I noticed that the headlight and the dash lights were still on. The key position was in "OFF" the way it is normally. I then started the bike and tried to shut it down by the key instead of the kill switch and it stayed running. The only thing that happens when I turn the key switch off is that the turn signal lights and brake light go off. I have since disconnected the battery so as not to run it down. Does anyone know what might be the problem.
Mark
				Your ignition switch may be knackered. It controls the on/off functions. Otherwise you have a short else where keeping the circuits live in spite of the switch position.
				I think that since the barrel seems not to be in great shape because the key slides out when it is in the "ON" position I should just buy another one. It costs less than 50.00$ anyway and that is probably the problem. If not, at least the ignition key goes in properly. Are you able to remove it easily? I had my manual but major cleaning by my wife resulted in it just disappearing. Does anyone have a diagram or the removal instructions possibly.
Mark
				Mark.......Randy (RPMracing - http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3Aflatkeyswitch&cat=30 (http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3Aflatkeyswitch&cat=30)) will have one too you in no time.
Its just 2 screws (or maybe bolts?) to remove and it plugs into the wiring loom. You can probably do it without even having to pull the fairing off.
				That is really great to hear. I will buy it from RPM tomorrow. Hopefully it doesn't take that long to arrive. It's a real pain disconnecting the battery everytime I use the bike. Thanks for the help, I'll post my results when I install it.
Mark
				Mark, check to make sure the key is not in the 3rd position which activates the parking lights.
				plug and play, no tank or fairing removal ,, i used a long extension bar, 1/4" with ten mm socket
				Instead of disconnecting the battery couldn't I just unplug the ignition. That makes it much easier if possible because it doesn't involve removing the seat everytime I stop.
Mark
				Quote from: chocker on July 13, 2012, 05:54:46 AM
Mark
yup.  Also by disconnecting the ignition switch you are narrowing the problem.  That is - if the problem persists then it's not the switch.
				Well I pulled the tank back to get access to the ignition switch connector and it was the problem. It was corroded. I cleaned it up and put some dielectric grease and it works great. Thanks for all the help.
Mark
				Quote from: chocker on July 13, 2012, 05:21:07 PM
That's why we're here. Be sure to donate to show your appreciation!  :good2:
				Quote from: Steve_in_Florida on July 13, 2012, 08:37:33 PM
Recent donations also put you into the club to get one my fork tools for the cost of shipping. http://www.fjowners.com/index.php?topic=6838.0 (http://www.fjowners.com/index.php?topic=6838.0)
				Quote from: FJmonkey on July 13, 2012, 08:58:07 PM
That's why we're here. Be sure to donate to show your appreciation!  :good2: donated yesterday , does that count :)
				Quote from: fj11.5 on July 13, 2012, 09:41:59 PM
Does this mean you are taking the offer for the tool for donating?
				im sure i could give one a good home mate, but send it off to someone closer that needs one  :good2:
