General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: buschdogg on July 11, 2012, 06:03:28 PM
Title: Help! No neutral light/Tachometer/turn signals/brake
Post by: buschdogg on July 11, 2012, 06:03:28 PM
Hi Guys,
I was riding home from work.. stopped to get a few things at the auto parts store and went to leave for home and noticed when I started the bike back up the tach wasn't working, I had no brake light (it's on, but not affected by either brake) no turn signals, and no neutral indicator.  I'm assuming this is a simple fuse.  The speedo worked fine and the gauges were still illuminated.  I'm sure someone here has the answer as to what fuse I need to replace and where it is?  (Or do I need a new set of gauges?)
Thanks!
Josh
Title: Re: Help! No neutral light/Tachometer/turn signals/brake
Post by: FJmonkey on July 11, 2012, 07:07:15 PM
Quote from: buschdogg on July 11, 2012, 06:03:28 PM
Hi Guys,
Thanks!
Josh
The speedo will not be affected by electrical issues, mechanical only. The rest sounds like a broken wire, circuit, fuse, etc...
Post by: andyb on July 11, 2012, 07:33:56 PM
Fuses are easy to check.  Pop the seat off and they're in a little holder near the battery.  Pull em and see what you find.
Post by: fj11.5 on July 11, 2012, 07:55:06 PM
unless you have an 1100 then the fuses are hiding in the left fairing panel , under a cover
Post by: Pat Conlon on July 11, 2012, 08:26:22 PM
You have a owners manual...right?
http://www.fjowners.com/index.php?board=34.0 (http://www.fjowners.com/index.php?board=34.0)
Post by: RichBaker on July 11, 2012, 09:08:11 PM
Sounds like the classic sticky start switch.... was the headlight working?
Post by: buschdogg on July 12, 2012, 01:54:12 AM
It's an 1100 :)
I reached under the left fairing and just touched the fusebox... bam.. worked great the rest of the night no problems.  Must have just been a loose connection.. maybe I'll look into it later, but it seems fine now :)
Thanks for the advice, though!
Post by: DreadRock on July 12, 2012, 09:26:01 AM
Not that i know alot about Fjs but if you have a loose wire and you just moved it and everything went back to work i would fix it now not later as it could leave you sitting on the sit of the rode !
Post by: fj11.5 on July 12, 2012, 05:36:50 PM
if you can be bothered, the fuse holder on fj1100,s can be shifted from the fairing , no wires to cut, and mounted behind the left side cover, easier access  (popcorn)
