General Category => Maintenance => Topic started by: Monkeylove on May 10, 2012, 05:46:45 PM
Title: Third times a charm...
Post by: Monkeylove on May 10, 2012, 05:46:45 PM
My third time using a gas tank sealant, and second time using  POR-15.
Its funked up my tank.  Globs of POR-15 all inside.
I might've rotated it incorrectly, and caused it to glob, but looking inside I'm amazed there are places that didn't even a lick of coating at all, with the amount of flipping and shaking I initially did.  This isn't what I was expecting, any suggestions?  It's been 24 hours.
Title: Re: Third times a charm...
Post by: Monkeylove on May 10, 2012, 06:01:39 PM
I think I might use the water hose and then some MEK...
Post by: fj11.5 on May 10, 2012, 06:10:26 PM
i used por-15 on my current tank with great results, tank had holes all through the base had to plug and silver solder , no leaks or globs of -15 ,, did you use the cleaning product in the tank  first , as por-15 likes a clean surface or it wont stick
Post by: grannyknot on May 10, 2012, 06:32:52 PM
Also, the tank must be dry dry dry. I proped a heat gun under my tank so that it blew through the petcock opening and then out the filler hole, then left it for a few hours. With the tank still hot from drying the por15
coated it very easily.
Post by: Monkeylove on May 10, 2012, 06:40:38 PM
Yes it was clean and dry... used POR 15 on my Honda it came out awesome.  I can't figure what the issue was here, though the FJ tank shape is a challenge.
But its all globbed and messed, and I just wouldn't have guessed it, I shook and rotated the hell out of it.  I guess I will just MEK it and then let it dry.  I'm really bummed out.
...grannyknot, I didnt realize you could use heat before applying POR 15...  http://por15bc.com/por-15.htm (http://por15bc.com/por-15.htm)
next time i will heat it up.
Post by: JMR on May 10, 2012, 08:38:06 PM
 Given the ethanol in fuel I don't know how well any coating will last.
Post by: grannyknot on May 25, 2012, 07:53:05 PM
[quote
[/quote]
Monkeylove, I don't know if you can or not by the rules, but I just figure if some kind of paint or coating has to dry or cure then heat will only help speed and adhere it to the surface. I have had great success with that philosophy over the years. From what you say, it sounds like you got a bad batch that had sat too long on the shelf and cured as you were turning the tank. I would encourage to try again, mind you, cleaning that mess out is not going fun. I have also had good results with CLR (calcium, Lime, Rust) Pour it in full strength, schlosh it around with a handful of nuts inside the tank to act as abrasion. You will have to seal off the petcock opening with tape or a rubber bung but it it also a good place to empty the nuts out after shaking. You can also use a magnet on a telescopic wand to grab the nuts. A lot of the worst rust I've found on M/C gas tanks appears on the inside topmost surface, that is just the other side of the tank surface that you look at the most.
GL, Chris
Post by: Klavdy on May 25, 2012, 08:14:11 PM
 The active ingredient in C.L.R appears to be Lactic Acid.
Post by: Brook on May 25, 2012, 08:46:01 PM
....... I also, used por15, with great results.
All of the area in-side the tank needs to be covered......[I used two cans] if not, the gas will get underneath the sealant and cause a mess............. [rotating the tank slow and easy].
if you do not know, the tube that is the gas entrance is about 1inch into the tank. So, you can turn the tank up-side- down [slowly] with the sealant in side and it will not come out.
Post by: grannyknot on May 27, 2012, 06:58:45 PM
Quote from: Klavdy on May 25, 2012, 08:14:11 PM
Klavdy, that depends on what country you live in and what legislation has been pasted there controlling
abrasive, corrosive and explosive chemicals (don't want those non existent terrorists getting a hold of
raw materials ya know) CLR use to be much more effective 10-15 yrs ago. I have heard that it has had a number of different chemical compositions  depending on where it is sold. But still, a good product.
Glad to hear you are back on your feet.
