General Category => General Discussion => Topic started by: Dads_FJ on April 17, 2012, 02:02:58 PM
Title: What happened to John "Hawke" Lawson?
Post by: Dads_FJ on April 17, 2012, 02:02:58 PM
Link seems to be dead.  www.hawkeoiler.com (http://www.hawkeoiler.com)
Title: Re: What happened to John "Hawke" Lawson?
Post by: MyFirstNameIsPaul on April 17, 2012, 02:54:47 PM
You mean Laurenson, not Lawson. Don't know where he went, but I bought a Hawke Oiler a few years back, just haven't installed it yet.
Post by: mst3kguy on April 17, 2012, 04:34:08 PM
wow, blast from the past.  john hawke laurenson.  totally lost track of him and some other oldies.  wonder where norske is these days...
Post by: racerman_27410 on April 17, 2012, 04:58:08 PM
i have a hawke oiler system..... works great and nowhere near as messy as the scott oiler. JMO
Post by: MyFirstNameIsPaul on April 17, 2012, 05:11:20 PM
Quote from: racerman_27410 on April 17, 2012, 04:58:08 PM
Did you use the supplied reservoir?  I felt it was a little on the smallish side and the way he made the vent looks to make an eternal ooze-covered reservoir.  I'm planning on replacing my ScottOiler this summer some time and I found that John's reservoir cap fits nicely onto a ScottOiler Oil bottle, so was going to use that instead, though I haven't figured out what to do about venting other than not filling all the way, which should work on the taller bottle.
Post by: Dads_FJ on April 17, 2012, 06:01:55 PM
Thinking of making a homemade jobbie, maybe using a reservoir like this...  http://www.ebay.com/itm/JDM-ROUND-ALUMINUM-350ML-OIL-CATCH-CAN-RESERVOIR-TANK-BLACK-ANY-CAR-/230776672012?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35bb5c8f0c (http://www.ebay.com/itm/JDM-ROUND-ALUMINUM-350ML-OIL-CATCH-CAN-RESERVOIR-TANK-BLACK-ANY-CAR-/230776672012?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35bb5c8f0c)
I don't recall the name of the manufacture who makes the solenoids and tubing etc... anyone recall?  Coundn't' find it searching...
Post by: Pat Conlon on April 17, 2012, 06:28:24 PM
I too have a modified Hawke Oiler on my '92 and it works great.
I use the Pro Oiler tip which oils both sides of the rear sprocket:
(http://www.pro-oiler.net/gallery_img/PO-schem-nozzle.jpg)
(http://www.pro-oiler.net/gallery_img/PO-nozzle-family-01g320.jpg)
(http://www.pro-oiler.net/gallery_img/PO-comp-nozzleV3-2g320.jpg)
Rather than a automatic feed (I don't trust) I installed a momentary contact button in my left switch cluster. On long trips, I just have to remember to give it 5 shots when exiting the freeway off ramp when stopping for gas....about every 190 miles or so... Works well.
Oiling via the sprocket, works best at 20-30 mph.
I use chain saw bar oil.
Years ago, I *had* a old gravity fed Scott oiler...never again.
A positive displacement pump, metering out a precise amount of oil, is the only way to go.
I was up in the mountains and had the Scott oiler dump a whole bottle of oil..... What a mess. :ireful:
Post by: MyFirstNameIsPaul on April 17, 2012, 07:56:56 PM
Years ago when I bought my ScottOiler I got it from the FJOC (http://fjclub.co.uk/), and they included a formed piece of sheet metal that allowed for installing the tip inside of the countershaft sprocket cover. I was skeptical that this would be adequate for oiling the entire chain. However, after 30,000 miles of use the chain has always been perfectly clean on all sides. I think that when the chain has heated up the oil does it's job and spreads out to cover the whole chain.
I'm also a fan of the bar and chain oil. Cheap, works, and biodegradable.
