General Category => Maintenance => Topic started by: micah360 on April 05, 2012, 01:38:58 AM
Title: bought a 1991 FJ1200 today and figured I'd be here a lot so... first question
Post by: micah360 on April 05, 2012, 01:38:58 AM
Hey guys... my name is Micah and I live in Colorado... FIRST POST HERE  :biggrin:  I just bought a 91 1200 today.  When I test drove the bike, I guess I didn't notice the squishy foot shifter until about 1/4 of the way home, so I pulled over and noticed that the whole shifter and foot peg were not solid... so I knew something was wrong here.
I got home and pulled the foot peg and shifter off and noticed that one of the nuts (the one that holds the shifter bolt) that is supposed to be welded inside the frame had broke.  So, I searched on this site real quick for this, and it looks like the threaded rivet thing would work.  Are there any other fixes for this???
AND... when I pulled off the stuff and revealed the frame... I noticed something else worse!  The bottom bolt (that I'm holding in the photo), had been sheared off inside the frame!  So this put me in an even worse mood... first day with a new/old bike... you know how it goes.  Then I pulled the foot brake side off too and that same bottom bolt is freaking broke on that side too!!!!
Are these bolts, primary bolts in holding the frame together.  Is it a big deal that I rode it 30 miles with it like this??  What is the best route to tackle fixing this?  Just try to extract the old threaded portion out of the frame and buy new bolts.
I'm kinda stressing that the seller didn't tell me this stuff, and I even asked him (after I paid him for the bike), if there was anything that would need my attention when I got the bike home.
It's a BEAUTIFUL MACHINE though and I love the way it drove home today, it felt great (except the peg thing).  I tested rear brake pretty good and it didn't feel like there were any weird frame issues going on there.
Anyways... thanks for listening... I'm sure I will be at this forum for a long time to come.
(http://www.360wd.com/fj/1991-fj1200.jpg)
(http://www.360wd.com/fj/bolt-1.jpg)
(http://www.360wd.com/fj/bolt2.jpg)
(http://www.360wd.com/fj/33.jpg)
Title: Re: bought a 1991 FJ1200 today and figured I'd be here a lot so... first question
Post by: RichBaker on April 05, 2012, 03:18:44 AM
Welcome aboard, Micah.....
I doubt they caused any other issues, as you found it's an occasional problem, but fairly easily fixed. Get an extracter kit from Sears, I've had very good results with these (http://www.sears.com/shc/s/p_10153_12605_00952157000P?prdNo=2&blockNo=2&blockType=G2) . You need a reversible drill, because you use them in reverse, and they usually unscrew under drill power...
Post by: ribbert on April 05, 2012, 05:49:16 AM
Welcome Micah,
You just described an FJ I bought recently, exactly!  The guy had been riding it with 3 of the 4 bolts that hold the subframes together missing/sheared/stripped.  Surprisingly, when I put it back together, nothing had "spread"
The gear lever shaft has a hole in the frame behind where the nut is (should be). I put a flat washer and nylock nut in there and used a large flat screw driver wedged against one of the flats (you can't get a spanner on it) to hold it while I tightened it from the front.
The sheared off one I drilled and removed with an extracting tool and replaced with a standard bolt.
The missing one had been moving around in the hole before falling out and had elongated and stripped the thread, I drilled and tapped it to 8mm (orig. 6mm) and fitted a new high tensile bolt.
I imagine this is the result of the bolts coming loose, or not being sufficiently tightened. I check these bolts regularly ( in fact they're the only bolts I check) on my other bike and 80k later have not had a problem. They are however, high tensile bolts.
It's a shame this took the gloss of the thrill of bringing the FJ home, but don't be alarmed, a sorted FJ is a terrific bike and they have very few vices and no place on the planet will give you more help than here.  AND, you got the sorted one, the one with all the good stuff already on it.  It's about time we had a new member with something other than another one of those bloody red and white things.
Post by: baldy3853 on April 05, 2012, 07:11:28 AM
Welcome Mitch Im also in the process of buying a 91 model for the 2 rallies I will be attending this Yr as your in Colarado, hopefully we will see you @ the rally, would be good to have to candy striped there rather then all those red & white go slow bikes  :sarcastic:.
Lots of really good guys here who are only to interested in helping out and supplying info on how to sort out the best bike other then their big brothers (FJR)  :yahoo:
Baldy
Post by: simi_ed on April 05, 2012, 09:25:44 AM
Quote from: ribbert on April 05, 2012, 05:49:16 AM
Amen!  Damn fast ambulances.  :shout:
Post by: Arnie on April 05, 2012, 10:16:11 AM
Micah,
I'll join in with a welcome.
When I found a broken lower frame rail bolt on my '91, I was able to just remove the threaded part with a sharp pick.  Since there is no tension on that part (once broken) it should come out easily.
When I went to replace the bolt I found that it was an 8mm bolt that went through a 10mm hole. I couldn't figure out why Yamaha had done this, and no one else had a good explaination either, so I re-tapped the receiver holes and used 10mm bolts in all 4 locations.  I've not had any problems with these bolts since.  That was 9years and 70,000 kms ago.
Post by: Pat Conlon on April 05, 2012, 10:55:27 AM
Welcome Micah, don't stress too much about the broken bolts. It happens sometimes, not often.
I do commend your thoroughness and diligence on your careful inspection. It is prudent.
You have received great advice and I hope you become a contributing member of our forum. A small donation is helpful.
Also FYI, we have a FJ Rally coming up in Colorado,  so will be in Gunnison the 2nd weekend in June and we would enjoy your company.
Cheers!  Pat
Post by: racerman_27410 on April 05, 2012, 02:45:00 PM
Quote from: Arnie on April 05, 2012, 10:16:11 AM
Micah,
+1   i also did this to my lower frame rails..... just didnt make sense to have an 8mm bolt in a 10mm hole.
welcome to the group brother!
KOokaloo!  :good2:
Post by: micah360 on April 05, 2012, 04:28:43 PM
thanks for the help everyone... I really appreciate it.  I will for sure be throwing a contribution to this site as soon as I get a few bucks into my paypal account.
I went to Sears and bought the extractor set that was linked above and I broke off one of the extractor bits.  Oh well, I guess I will just re-thread it to 10mm as suggested and use new bolts.
After looking this over again and again... I believe these lower bolts are failing because the 8mm bolt is going through a 10mm hole (as stated above) and when you rock it on and off the center stand the torque on them is what is breaking them.  That's just my hypothesis.
By the way... is the tube connecting the frame (at the lower bolts) hollow or solid?  And, does anybody have a guess on how long the stock bolt is (cannot tell because I couldn't get the broken pieces out)??
thanks....
Post by: 1tinindian on April 05, 2012, 11:55:07 PM
I'm going throught the very same thing with my 91.
The left side lower bolt was missing when I took the AL foot rest piece off to polish it.
When I looked in the hole, the bolt was broke off and I started to drill it out, BUT man, than broken bolt won't drill worth a damn.
I gave up on it for tonight, but I will have to get back on it with a new approach.
I check the other 3 bolts, and they were all there plus lock tight had been used, so I used a torch to heat them up, and they came right out.
Any advice on how to drill this hard bolt out would be great.
Post by: simi_ed on April 06, 2012, 09:17:56 AM
Leon, drilling bolts is never fun!  You will need a sselection of left-hand twist drilll bits and a VERY sharp center punch.  You will need to mark center of the bolt, then start drilling with a small bit.  You must drill down the center of the bolt, or else you'll damage the mating threads!!!
Use plenty of oil!  Also, pre-lube the whole area with acetone/ATF mix, at 50/50.  The will help the bolt when it deciedes to say UNCLE!
Drill at a low RPM, in reverse.  Start small, then keep increasing the diameter, but stay below the minor diameter of the bolt.  At some point, the bolt WILL yield.  At that point, I'd wash it out with WD-40, run a tap through the hole to make sure the threads are clear and not mucked up.  Then wash it out again with WD-40.
A good source of left had drill bits and a sharp centerpunch is McMaster-Carr. I'd go with either metric or wire gauge bits, to get the required resolution in the bit sizes.  McMaster-Carr is not cheap, but they don't sell crap, so pony up, you'll be glad you did!
http://www.mcmaster.com/#left-hand-drill-bits/=gzkrk2 (http://www.mcmaster.com/#left-hand-drill-bits/=gzkrk2)
Good luck!
Post by: micah360 on April 06, 2012, 10:06:04 AM
Well the extractor that broke off inside the bolt is going to be a huge pain to drill out as it's tough as nails.  I tried a colbalt bit for awhile and a diamond dremel attachment for awhile with very little progress.  Getting this extractor bit out is going to prove to be a very long process I'm afraid.
Does anybody know how far the stock bolt threads into the upper part of the frame?  Does it thread all the way through it and into the tubular support that connects the other side??
Post by: 1tinindian on April 06, 2012, 10:48:31 AM
Thanks Ed, I have drilled alot already, mostly as you described, and I think I'll be trying some carbide drill bits tonight.
That left side looks like it must not go all the way through, correct?
That must have been a grade 8 bolt as hard as it is, plus being lock-tightened on top of things make it a challenge.
I have my work cut out for me this weekend, and will be happy to report back when the job is done.
Post by: glfredrick on April 06, 2012, 11:40:54 AM
A kit that has really helped me over the years is this one from Snap On:
http://buy1.snapon.com/catalog/item.asp?item_ID=630634&group_ID=675450 (http://buy1.snapon.com/catalog/item.asp?item_ID=630634&group_ID=675450)
The kit features drilling guides that can either slip over the stud/bolt or that can be inserted into the bore if the bolt or stud is broken off under the surface.  Then a hardened drill bit is used to bore a hole into the bolt or stud.  A splined extractor is driven in, and a collar with the same splines is used to turn out the extractor.
Works better than the wedge type extractors, which generally expand the problem bolt to a point where it is more difficult to extract than before.
An alternative is to weld a nut to the exposed bolt or stud then use a wrench to turn it out.  Works well also but requires a MIG and a steady hand!
Most extractors that break off can be removed with hammer and chisel, as their hardness is also their weakness.  They will shatter into pieces.
Post by: 1tinindian on April 06, 2012, 07:59:10 PM
As promised, I'm here to tell you what I did to get that broken bolt out of the frame.
Of one of the many different drill bits I bought to attack this problem, I started with a carbide tipped masonry bit...and the damn thing went right through the hard bolt.
It was a 1/8" bit.
I then heated the broken part of the bolt up, still inside the frame, to loosen the lock tight, then lightly tapped a torx screwdriver into the new hole I just drilled, and simply turned the broken bolt outta the hole.
I then chased the hole with a tap and there you have it, a clean threaded hole ready for a new bolt.
Good luck guys, it can be done much easier than what I was prepared for.
Post by: Yamifj1200 on April 06, 2012, 08:21:32 PM
"Well the extractor that broke off inside the bolt is going to be a huge pain to drill out as it's tough as nails."
When you drilled the hole in the broken bolt, did you drill all the way through the broken bolt or just enough to get the extractor installed? If you drilled through the broken bolt there is a chance you can drive the extractor through the hole or break it to pieces and drive it through. If its a blind hole it going to be tough to drill through the broken extractor. You might be able to use a small carbide bit next to the extractor to open the hole up and still not mess up the threads in the frame. Good luck and lets us know how it turns out..
Eric M
Post by: mst3kguy on April 06, 2012, 09:17:20 PM
i had a broken frame bolt on fj #1 and it was a motherfucking bitch.  my engineer father-in-law who i trust with all things mechanical helped me out, but i broke off the extractor bolt, and spent the better part of a day and a half using all kinds of dremel bits to drill out all that fucking shit.  i believe i drilled it out to a larger diameter, then dropped a fuckload of liquid jb weld into the hole, then put a bolt in there and hoped for the best.  that was one of the most tedious fucking things i ever did, had the bike leaned over at a severe angle so i could get as close to vertical whilst drilling.  i will not do that fucking exercise again.  went from using a drill and extractor bolt, to a hand extractor, it seems the drill spun too fast even at lowest setting to get the right bite.  God those two days sucked ass.  good luck.
Post by: andyb on April 06, 2012, 09:36:56 PM
Tell us how you really feel.   :rofl:
Post by: simi_ed on April 07, 2012, 12:01:35 AM
Feel better now Dean?  Don't hold back ...  :empathy3:
Post by: micah360 on April 07, 2012, 01:11:25 AM
this about sums up how I'm feeling about that broken extractor right about now... it's very hard going so far.  I haven't even really made a dent in the process.
I wish I would have known then what I know now and did it by hand and not with my drill.    :dash2: :dash1: :dash2: :dash1: :dash2: :dash1:
Quote from: mst3kguy on April 06, 2012, 09:17:20 PM
Post by: The General on April 07, 2012, 03:56:08 AM
i had a broken frame bolt on fj #1 and it was a motherfucking bitch. ...............  God those two days sucked ass.
Yeah, the hand job fixes most things.  :empathy2:
Post by: Mark Olson on April 07, 2012, 12:06:42 PM
hell ya.
preachin to the choir.
Post by: baldy3853 on April 07, 2012, 08:08:01 PM
Quote from: The General on April 07, 2012, 03:56:08 AM
:rofl2: and you know all about hand jobs there General :sarcastic:  :sarcastic:
Post by: micah360 on April 09, 2012, 04:41:40 PM
You're correct... it was a motherfucking bitch (no other words could better describe it).
I finally got it all done today though... lots of time wasted (and money)... but it's done!  WHEW!!!!  :yahoo:
Post by: rktmanfj on April 09, 2012, 04:46:56 PM
Quote from: micah360 on April 09, 2012, 04:41:40 PM
Nice work, Micah!  Way to hang in there!       :good2:
