General Category => Modifications => Topic started by: 93fj1200 on February 07, 2012, 09:55:27 AM
Title: has anyone mounted a trailer hitch on an FJ?
Post by: 93fj1200 on February 07, 2012, 09:55:27 AM
I would like to know if anyone has mounted a trailer hitch on an FJ.  I have a 1993 FJ1200.  I know that there is a lot of suspension movement on the type of bike and a regular hitch as I had on my Venture Royale doesn`t work.  There are only a few mounting points on the bike and I am not sure if they would be strong enough. If anyone has photos, they would be helpful.  I was in an accident with my Venture Royale in Mexico and I have my trailer stranded there. I would like to go get it but I have my FJ now.  I do not remember seeing a hitch mounted on a monoshock type suspension before but I positive I can`t be the only person who could use this. Your help would be appreciated.
Greg
Title: Re: has anyone mounted a trailer hitch on an FJ?
Post by: rktmanfj on February 07, 2012, 10:06:12 AM
From the old, OLD FJ archives:
>>{1.7} Trailer hitches on FJs?
This set up actually works pretty well and I'm of the belief that its safer to tow it than stow it on the bike. I had a hitch custom made and it cost about 100.00. It mounts to the rear exhaust mounts, the turn signal mounts and another mount on the frame about a foot in front of the turn signal mount. This third mount point was already on the frame and I think its for luggage. I pulled a trailer with a Goldwing in the past and this setup feels about the same. Of course the mileage goes down by about  20 percent (about 42 down to around 34). You can definitely feel it back there, when its fully loaded the trailer grosses about 350 pounds. I probably notice it most in roll-on acceleration, instead of 70 to 90 in a heartbeat its more like two heartbeats. Several very critical points: The swing arm must clear the hitch through it's full motion (the rear wheel has 4.8 inches of travel). The ball on the hitch should be 12 to 15 inches off the ground when the bike is on the ground. Run 5 wires to the trailer not 4: Brake, ground, left turn, right turn, and running lights. Put a swivel connection in place of the ball or on the trailer tongue.
[Mark Wallace]<<
Post by: Zwartie on February 07, 2012, 10:12:03 AM
Quote from: 93fj1200 on February 07, 2012, 09:55:27 AM
Greg
I haven't seen an actual FJ with a hitch but my brother picked up a single-wheel trailer for his ST1100 last year. We saw the manufacturer at the Toronto motorcycle show last year and this year and he had a Hayabusa at the show with a hitch and trailer. Go to http://www.thirdwheeltrailers.com/index.php/home (http://www.thirdwheeltrailers.com/index.php/home) to check it out. I believe the thing to do would be to connect it through the rear axle assembly.
Good luck and post pictures if you get something to work.
Ben Zwart
London, ON
1992 FJ1200
1977 KZ200
Post by: 93fj1200 on February 07, 2012, 11:33:02 AM
Thanks for the website. I read it and they say that you need a hollow axle shaft for their system to function. If you think the roads in Ontario are bad, check out Guatemala and Honduras, I never pushed it past past 90kph in Honduras, there was potholes bigger than a car and 2 feet deep. And on one place near Esperanza, Honduras, the road changed from a 4 lane to a 30km goat trail in a few seconds.  Beautiful scenery if you want to take a chance and take your eyes off the road for a look.
Post by: SlowOldGuy on February 07, 2012, 03:07:50 PM
Hi Greg Hunter,
Welcome to the site.
Post by: racerman_27410 on February 07, 2012, 04:05:04 PM
you could always put on a FZ1 or thunderace swingarm... they both have hollow rear axles   :good2:
Post by: 93fj1200 on February 09, 2012, 05:39:30 PM
Well, thanks for the information but I still haven`t found anyone who has installed a trailer hitch on an FJ. Hard to believe that, of all the FJs sold, there is nobody who has done one. There seems to be so many people who are very inventive here in this website.
I am in Panama so I am a little limited to what can get done here. They don`t have the resources like North America or Europe.  I was thinking about getting a longer axle bolt made up by a machine shop to give me another strong mounting point and use that with the exhaust mounts to provide a stable strong mounting point for the hitch. Any suggestions on how the bolt should be done or any other helpful considersations? Thanks in advance.
Greg
Post by: FJmonkey on February 09, 2012, 06:13:18 PM
Quote from: 93fj1200 on February 09, 2012, 05:39:30 PM
Greg
I thought I some posts a while ago of someone fabbing up some bit tow a trailer. I could not find it when I searched the files. Anyone else remember this?
Post by: tmkaos on February 09, 2012, 06:21:39 PM
About 6 months ago there was one listed at this site www.trademe.co.nz (http://www.trademe.co.nz), specifically for an FJ. Someone either bought it or it never sold. I've just checked and it's no longer listed, but another Kiwi FJer might have picked it up.
From what I remember from looking at the pics it seemed to have washers welded on the ends of 2 bars that replaced the standard washers on the rear axle on either side of the swingarm. The bars then protuded to the rear of the swingarm and were bent into a U shaped, with a coupling centred behind the wheel.
As long as you had the coupling parts I can't imagine any engineering shop couldn't fabricate something for you.
As an engineer myself, I imagine this attachment point would be strong enough - within reason. What I mean by that is if you load that trailer with a 1/2 ton then crack that throttle wide open you might find yourself with 2 half-bikes but sensible usage in my opinion would be ok. The only downfall I see is the single attachmnet point would allow the whole unit to pivot if enough vertical force was applied - it might need another attachment further along the swingarm to stop this from happening.
I've never seen a trailer hitch (down here they're called tow bars) on a bike so correct me if I'm wrong but you are suggesting using both the swingarm and exhaust mounts to attach to? Both of these components move independantly of each other, the exhaust mounts are attached to the frame whereas the swingarm pivots from the frame as the shock compresses... By using both of these mount points I fail to see how you can do that without the effect of locking the bikes rear suspension up...
In my opinion the only place to attach the hitch is off the swingarm by itself or the body by itself - obviously the swingarm, and in particular the axle, stays a static distance from the road surface, thus providing a more stable mount and would be my prefered option,  and the body of the bike moves up and down relative to the road as the suspension compresses and extends..
Just my 2c worth anyway... I'll do a bit more searching and see if I can come across some pics for you of the one I saw...
Happy riding,
James
Post by: baldy3853 on February 13, 2012, 07:35:24 PM
Greg
I ran a towbar on my 93 model for about 5 yrs and never had any trouble with it, cant supply a pic as Ive since sold the bike, will look thru my old pics later and see if i can find it, did a lot of K's with the trailer on will see if Klavdy has any pictures.
My trailer was a home made job weigthed in at 65kilograms and had a a 500litre capicity, most important that when the trailer is loaded the drawbar weight does not exceed about 20kilos. Have the trailer axel unsprung and run nomore then 15psi in the tyres.
When towing never really noticed the trailer on the back except on down hill corners under brakes.
Still have the trailer which I now tow behind my FJR, will get some pics of it up here soon
Baldy
Post by: Rich Pleines on February 14, 2012, 11:08:58 AM
FJ trailer hitches available for sale.
"Most of our Motorcycle Trailer Hitches mount in a very similar fashion.  The draw arms or pull arms usually attach to the passenger footpeg mounts or to the muffler mounts.   The upright weight bearing arms usually attach to the frame, on the fender brackets, saddle bag mounts or sissybar mounts. They are bolt-on and you don't have to make any permanent changes to your motorcycle. "
http://www.customcruiserchrome.com/ (http://www.customcruiserchrome.com/)
YAMAHA 1200 CC FJ 1986 +
SKU 99
Weight     20.0 lb
Price     $245.95
Qty  :unknown:
Post by: 93fj1200 on February 15, 2012, 10:47:02 AM
Thanks for your ideas, you are right about the mounting points. What do you think about if I use the washer idea but use a bar and a clamp going a little further up the swingarm to provide the point of stability that is needed?
Post by: 93fj1200 on February 15, 2012, 10:51:34 AM
Quote from: Rich Pleines on February 14, 2012, 11:08:58 AM
SKU 99
Thanks for the website. I am sending them an email to find out how they mount it or what it looks like. They only have photos of traditional trailer hitches in their gallery on cruiser/touring bikes, not sport or sport/touring bikes. I tried adapting one of those hitches when I was in Mexico and I couldn`t get it to work because of the huge suspension movement.
Weight     20.0 lb
Price     $245.95
Qty  :unknown:
Post by: 93fj1200 on February 15, 2012, 10:53:44 AM
Baldy
[/quote]
Thanks, like they say, a picture is worth a thousand words. Do you remember the mounting points or what was used?
Post by: 1tinindian on February 15, 2012, 12:55:08 PM
Sorry that I don't have any details on this set up, but I'm sure some of us here may remember it! :bomb: :bad:
(http://img.photobucket.com/albums/v338/1tinindian/Motorcycles/316460_2320646572916_1152099382_32167920_1465187619_n.jpg)
Post by: Klavdy on February 15, 2012, 01:11:35 PM
Quote from: 93fj1200 on February 15, 2012, 10:53:44 AM
Baldy
[/quote]
I'll have a look mate but you'll have to be patient.
It's from quite a few years ago and it's on a drive somewhere.
Following Baldy with his trailer on, it tracks straight and true, you just have to remember that you have one on as it is easy to cut it across the centre lines.
Post by: tmkaos on February 15, 2012, 01:41:56 PM
Quote from: 1tinindian on February 15, 2012, 12:55:08 PM
I think i just threw up a little in my mouth...  :bad: :negative:
Post by: rktmanfj on February 15, 2012, 07:20:35 PM
That's a different pic, though... Leon, did you buy it?
Post by: 1tinindian on February 15, 2012, 07:57:12 PM
Quote from: rktmanfj on February 15, 2012, 07:20:35 PM
I guess you'l have to make it to the Colorado Rally and find out for yourself! :yahoo:
Post by: simi_ed on February 16, 2012, 02:12:31 AM
+1  :bad:
Post by: rossco on February 16, 2012, 07:06:43 AM
big bro did -best investment you'll ever make
Post by: 93fj1200 on February 21, 2012, 10:02:42 AM
still looking for more information and photos on how it is mounted. that fj with trailer is somebody with a lot of imagination, i have seen a lot of harleys done up like that when i was travelling in mexico and attending a lot of bike events. if everyone was the same, it would be a boring world.
Post by: ally on February 27, 2012, 02:04:00 PM
there is an FJ here in the UK for sale on ebay that has a towbar fitted
if you contact the owner I'm sure he'll provide more info....
http://www.ebay.co.uk/itm/1990-YAMAHA-FJ1200-BLACK-/320856381789?pt=UK_Motorcycles&hash=item4ab487d95d#ht_518wt_1344 (http://www.ebay.co.uk/itm/1990-YAMAHA-FJ1200-BLACK-/320856381789?pt=UK_Motorcycles&hash=item4ab487d95d#ht_518wt_1344)
Post by: sfeilberg on March 05, 2012, 04:07:21 PM
Hi all,
I have an 1988 1200 with a trailer hitch and haul a 150kg(300pound) tentwagon. If it's still relevant I could post some pictures. I haven't quite figured out how to do this yet.
Anyway. I haven't properly introduced myself yet. But I live in Denmark. I have a white and grey 1988 FJ1200 with a trailer hitch, my wife has a blue and white 1985 FJ1100. We also have a 1985 FJ1100 with a Mega Comete Side-Bike sidecar with a trailer hitch. Actually its the same hitch that I swap from bike to bike. The Trailer is a tentwagon, sleeping for two. We have been through most of the countries in europe with the tentwagon and have never had any issues.
We got the sidecar-bike because we now have 2 small children.
Email me if your interrested as I dont look in this form that often. I looking for a good mirror swap with indicators...
Søren
Post by: rosso75 on March 06, 2012, 02:04:32 PM
Quote from: tmkaos on February 09, 2012, 06:21:39 PM
I have a '90 FJ that's in pieces currently, but going back together.  In the process, I want the ability to tow a trailer, so for me this thread is rather timely.
Anyway, I've been looking at every site I can find for trailers, and I've seen the trailers that mount to the swingarm.  My immediate thought was that it seemed like a really bad idea, for several reasons.  Take these thoughts for what their worth.  I'm no expert on anything except maybe sleeping and drinking beer.
:drinks:
First of all, wouldn't you be increasing your unsprung weight, and wouldn't that be bad?  If your trailer has a tongue weight of 20 pounds, you essentially just made your rear wheel 20 pounds heavier.  That has to have a negative effect on suspension response, doesn't it?
Second, I don't buy the idea that the suspension maintaining a static distance from the ground is a good thing.  If you attach a trailer to the swingarm, everything in the trailer is going to get shaken to death as the suspension travels through its motion.  The body on the other hand, would maintain a more steady path of travel.  For example, and old Ford commercial...
1971 Ford Pickup Truck Commercial (http://www.youtube.com/watch?v=6DC_7UDx9dE#)
Just my two cents worth.
Post by: sfeilberg on March 06, 2012, 02:53:29 PM
Well, I have never seen a car trailer mounted to the suspension of a car...  So that's probably not the way to go. I had my trailer hitch done by EZS in Holland (www.ezs-sidecar.com (http://www.ezs-sidecar.com)). There is a button for english. After installation the bike, trailer hitch and the trailer has to checked by the ministry of transport to make it legal.
(http://fjowners.com/gallery/3/227_06_03_12_2_41_24_4.jpeg)
(http://fjowners.com/gallery/3/227_06_03_12_2_41_23_3.jpeg)
(http://fjowners.com/gallery/3/227_06_03_12_2_41_23_2.jpeg)
(http://fjowners.com/gallery/3/227_06_03_12_2_41_23_1.jpeg)
(http://fjowners.com/gallery/3/227_06_03_12_2_41_22_0.jpeg)
I hope it helps.
Søren
Post by: skymasteres on March 06, 2012, 09:13:03 PM
Since they have already worked out the design I wonder if it would be possible to get one from them...
Post by: rosso75 on March 07, 2012, 12:22:50 AM
Looks pretty simple.  I would thing it would be easier/quicker/cheaper to have a competent shop fabricate one rather than pay shipping and whatever else is involved in getting one from somewhere on the other side of the world.
Post by: tmkaos on March 07, 2012, 12:28:11 PM
Quote from: rosso75 on March 07, 2012, 12:22:50 AM
I'd be finding out for sure first whether or not it's cheaper to manufacture - that drawing alone has absolutely none of the information required to make the towbar apart from showing what it looks like and where it connects.
You would absolutely need to give them the bike to measure up, along with all the photo's from the posts above.
You will have to pay for them to measure the bike up, there's another couple of hours labour costs right there.  You will be paying for the material used to make the bar, plus their markup along with the inflated price of the welding rods used, and time on any equipment used for driling holes, bending pipe etc. Then it has to be painted/powdercoated. If they do it you pay for it plus markup again.
Just some things to consider...
Happy riding  :good2:
Post by: rosso75 on March 07, 2012, 01:58:21 PM
All valid points.  I was thinking about it mainly from the perspective of the original poster, who it seems is stuck in Mexico with a trailer, and no hitch on the bike he wants to tow it with.
Post by: tmkaos on March 07, 2012, 02:29:26 PM
In engineering you see a lot of people trying to reinvent the wheel. Case in point we have a guy getting us to make a bow thruster for his 40ft launch, to the degree of getting us to manufacture the hydraulic motor (casings, impellors, the whole thing) to power the impellor. So far we've put in over 45 hours of shop time on it. Sometimes it's just easier to buy what you need when someone else has already proven the design. Our guy didn't think it all through before he put his wallet where his mouth is.
I just want to make sure that 93fj1200 was aware of some of the processes involved in paying someone to make something that someone elso has already made.
In saying that, I have been to South America and if Mexico is in any way similiar to there then there will be some backyard mechanics/engineers  down there with enough talent and skills to make a decent job of making a similiar towbar unit with those pictures from sfeilberg and the bike to work off.
Best of luck to you  :good2:
Post by: 93fj1200 on March 10, 2012, 04:50:20 AM
Thanks everybody!! Your input is greatly appreciated. I´ll post a foto when I am done.
Post by: rosso75 on May 01, 2012, 06:48:06 PM
Quote from: 93fj1200 on March 10, 2012, 04:50:20 AM
So what ever happened?  Did you get the hitch?  Abandon the trailer?  What?
Post by: theoldgalah on July 10, 2012, 06:43:06 AM
Hi
I have a classic industries trailer hitch on my FJ1200.They are light,cheap and work very well and are adjustable to some degree.They attach to the Pillion footpeg bolt and The pannier mount on the rear rear frame brace.I tow a large fiberglass trailer again from classic industries and never even notice it's there when Im riding I will find some pics and post them.
Post by: theoldgalah on July 10, 2012, 06:58:58 AM
Here are some pics of my beast
(http://img.photobucket.com/albums/v359/andiec/bikewithtrailer_9427.jpg)
(http://img.photobucket.com/albums/v359/andiec/bikeTbarcloseup_9402.jpg)
