General Category => Maintenance => Topic started by: jerryXR on February 04, 2012, 10:11:37 PM
Title: Float adjustment ?
Post by: jerryXR on February 04, 2012, 10:11:37 PM
Well i made a stand to hold my carbs and i'm checking float height by using
a tube off the drain nipple. My ? is my manual says 2 to 4 mm above the line
on the carb bowl. Do they mean above the gasket surface of the bowl? Seems
like that would be to high?
thanks
Title: Re: Float adjustment ?
Post by: flips on February 04, 2012, 10:22:28 PM
Hi Jerry.
I'll prefix this with "I'm not an expert but..." I would agree that 2-4mm above would be too high.I would guess that 2-4mm below would be closer to the mark.I have never tried this method.I have always just set the float height (22mm) on the bench with the bowls off.I'm sure a more knowledgeable member will chime in.
Cheers :drinks:
Jeff P
