General Category => General Discussion => What did you do to your FJ today? => Topic started by: Skivvy on January 31, 2012, 10:18:41 PM
Title: Started list of replaceable parts
Post by: Skivvy on January 31, 2012, 10:18:41 PM
Going to try and remove the aluminum frame parts and try buffing with scotchbrite wheel. Is this major to remove?
Parts short list (still available from Yamaha)
Speedo cover
Front fender 1
Front fender 2
Windscreen (aftermarket only?)
Right side Mirror
Title: Re: Started list of replaceable parts
Post by: Pat Conlon on January 31, 2012, 11:02:52 PM
The aluminum side frames: one side is easy, the other side you have to remove the swing arm pivot thru bolt.
Put the bike on the center stand and put a block under the back tire to support the weight of the swing arm and tire assembly and push thru the pivot bolt with a long socket extension or long drift punch.
If you have the time why not just take the back wheel off, disconnect the lower shock mount and remove the swing arm so you can clean and lubricate the swing arm bearings and relay arm/linkage bearings? No big deal.
Be careful with a motorized buffing wheel (drill motor) with aluminum, if you press too hard or put uneven pressure, you will get ripples in the aluminum surfaces. Light even pressure is key. I polish by hand. I get better results that way.
Use some paint stripper on the aluminum to remove the old clear coat. It is much easier that way, than trying to buff off the clear coat.
Cheers!
Post by: FJmonkey on January 31, 2012, 11:12:54 PM
Quote from: Pat Conlon on January 31, 2012, 11:02:52 PM
Cheers!
Trust Pats words on this, his bike will blind anyone within 100 feet of his bike in clear skies when the sun is out. I will bet money that he polishes while he is riding, maybe not in the corners but during some of the longer stretches when he can divide his time between looking forward and staying shiny.
Post by: Dads_FJ on February 01, 2012, 09:45:24 AM
Careful it's a trap.  Starts innocently enough, "just remove your swing-arm to lube it".  Then it's "might as well polish it since it's removed, or better yet fit one from a Thunder-Ace - polished of course".  Next thing you know you're pawning stolen goods to satisfy your fix of Mothers polish, (which Pat is a distributer of I'm sure).
Post by: 1tinindian on February 01, 2012, 12:22:38 PM
Quote from: Dads_FJ on February 01, 2012, 09:45:24 AM
No, Simichrome is where its at, not that damned Chip Foose spuzz !
Post by: Pat Conlon on February 01, 2012, 02:49:23 PM
Sssssh guys, don't spook him, he's new.......Let's creep up on him slowly...........
Post by: Dads_FJ on February 02, 2012, 03:54:07 PM
Cheers!
Anyone ever fit a grease fitting aka zerk on the swingarm?  I did a search and didn't see anything regarding this.
