General Category => Maintenance => Topic started by: Alf on January 26, 2012, 11:20:54 AM
Title: Goldfren pads. References, please
Post by: Alf on January 26, 2012, 11:20:54 AM
Hola amigos:
Has anybody used Goldfren pads?. These are cheap in eBay and looks ok. The OE Yamaha R1 pads for my blue calipers are very expensive, even althought are perfect, so I am doutful
Title: Re: Goldfren pads. References, please
Post by: FJ111200 on January 26, 2012, 11:30:56 AM
I'm using a set of front pads in my XJR. Same calipers as standard 3CV's, and i've had no problems, good as anything else i've used.
Some sort of ceramic based material.
Post by: Harvy on January 26, 2012, 04:48:46 PM
Alf, I am using them in my rear calliper at present, and have a set ready to go into the front. They work just fine!
Post by: Alf on January 27, 2012, 03:41:31 AM
Thanks you guys. I´m going to try a set then
Regards
Post by: Alf on March 25, 2012, 04:36:13 AM
Hola!
Only to inform
I fitted a pair front in my CBX 750 2 months ago. Far superior to the previous ferodo ones fitted, the improvement has been incredible!.
When I was reading test from the CBX, all of them were speaking about the wonderful brakes. Mine were horrible, even with everything carefully restored and with metallic hoses, so I even adapted a FJR 1300 lever. Now I´ve refitted the OE one (I want keep the Honda original spec)
The pad material is very soft, and very similar to the Yamaha R1 OE pads that I fit in my FJ
For half of the price of the Yamaha ones I think the Goldfren deserve a try. I bought them from http://stores.ebay.co.uk/Goldfren-Motorcycle-Brake-Pads?_rdc=1 (http://stores.ebay.co.uk/Goldfren-Motorcycle-Brake-Pads?_rdc=1) Excellent people!
Regards
Alf
