General Category => Maintenance => Topic started by: bigbore2 on January 13, 2012, 11:29:15 AM
Title: air pressure
Post by: bigbore2 on January 13, 2012, 11:29:15 AM
Just wondering what you recommend as far a tire pressure goes front/rear.  The manual says 26 front and up to 36 rear depending on weight of load.  26 seems a little low?  What do you guys run.  Both my tires are Michelin. I can get the size if needed. Stock rims [16"], I believe.
Title: Re: air pressure
Post by: Pat Conlon on January 13, 2012, 11:58:11 AM
No, you have misread, 36psi front and 38-42psi rear.  26 psi is much too low for the front.
We have free owners manual's you can download in the Files section.
Post by: simi_ed on January 13, 2012, 12:54:48 PM
I typically run 38-40 in the front, and 42 rear ALL THE TIME.  Hard tires don't squirm, and will not cup as soon.
YMMV
Post by: SlowOldGuy on January 13, 2012, 01:22:41 PM
Hey Ed,
Do you use Amsoil motorcycle specific air in your tires?  :-)
Personally, I run the semi-synthetic radial air in my tires.  36 front, 43 rear
Be aware that you can't mix bias ply and radial air in the same tire.
Post by: simi_ed on January 13, 2012, 02:06:53 PM
No Dave, It's Amsoil Synthetic air.  Jeez ...   :rofl:
Post by: racerman_27410 on January 13, 2012, 04:14:30 PM
36 front/40-42 rear
KOokaloo!  :good2:
Post by: bigbore2 on January 13, 2012, 04:38:35 PM
Thanx for the info.  I will increase to 36 front and 40 rear to start.  It has been a while since I been on a road bike, still learning, but thanx to all. I love this site!
