Hi Guys,
I'm a long time FJ1200 lover. Always liked the way they looked as a kid, like they are going a hundred sittin stilll. then I actualy got to ride one and i was hooked! I now own two s red and white 86's and are identical in almost every way for the moment. I want to lower/ stretch/bigger tire the new one, just need to come up with a running motor. i already have a extra swing arm to do the stretch but I will need plenty of tech to get another tire/wheel on there. need a chin fairing also. They are on sale right now for around $50 bucks on the net so unless there is a red/white one out there for cheap then I'lll go with new. supposedly they have fixed the weak spot on left side.
Welcome to the group!
there isnt a weak side of the chin fairing.... there are only clutch slave cylinders leaking dot 4 on the fiberglass and mis aligned mounting tabs putting it in a bind.
add the two things together and you have a broken ear off the chin fairing.
GOod luck on your project.
Kookaloo!
