General Category => Modifications => Topic started by: FJTillDeath on November 03, 2011, 07:22:55 AM
Title: TIny mod - hooter
Post by: FJTillDeath on November 03, 2011, 07:22:55 AM
I got this baby for next to nothing
(http://i1108.photobucket.com/albums/h410/FJTILLDEATH/Photo0103.jpg)
(http://i1108.photobucket.com/albums/h410/FJTILLDEATH/Photo0102_1.jpg)
It says its a 12 volt so the FJs battery should handle it right? Also its says its 105db, thats louder than the FJs isnt it?As for mounting, I am sure it will work, not hard to put it on I am sure.
Title: Re: TIny mod - hooter
Post by: 1tinindian on November 03, 2011, 12:32:04 PM
Here you go fella, nobody wants to hear about your "TINY mod- HOOTER", so I'll help you out just a bit!
(http://img.photobucket.com/albums/v338/1tinindian/Other/hooters.jpg)
Now thems is HOOTERS! LOL!
Sorry, I couldn't help myself, I hope the "horn" works out for you!
Post by: hein on November 03, 2011, 03:57:29 PM
Quote from: 1tinindian on November 03, 2011, 12:32:04 PM
If a horn is called a hooter in South Africa I'm not so sure I want to know what a horn is down there and I'm positive I don't want to see a graphic image.
Post by: ninjamuder on November 03, 2011, 04:10:20 PM
i SWEAR i saw this pic on ehowa.com about a week ago!!!!.........
btw, nice beeper!!....yes, it will work.....you might need to "tune" it tho for the most volume.....the tiny flathead on the back will alter the resonance frequency to get the loudest sound, and yes, you do need to check it......especially on the cheaper horns out there, about half the time, they are out of adjustment a bit........makes em sound like a strangled goose!!
Post by: markmartin on November 03, 2011, 04:14:02 PM
Thanks Leon, I was a little disappointed with the original post.  :-)
Post by: Pat Conlon on November 03, 2011, 04:56:43 PM
A perfect example of your tax dollars at work......Those NSA folks have some bitchen satellites huh?
Post by: flips on November 03, 2011, 07:45:29 PM
Hi there.
Is your fj "hooter" not working well?.It might pay to check the volts actually getting to your "hooter".Could be a poor ground, bad connection in the wiring,or poor contact in the "hooter" button itself.You could test your "hooter" direct to the battery.A relay mod for your "hooter" would work well.I decided my fj could use some bigger "HOOTERS" so  installed some "AIR HOOTERS".Big "HOOTERS" are fun after all!  :rofl2:
Cheers :drinks:
Jeff P
Post by: nvmike24 on November 03, 2011, 10:40:41 PM
I think everyone should have bodacious, loud hooters on their FJ, just sayin is all.
Post by: FJmonkey on November 03, 2011, 10:47:30 PM
Quote from: nvmike24 on November 03, 2011, 10:40:41 PM
Just like FJ Kookalooo, you can never have too much!!! :good:
Post by: FJTillDeath on November 04, 2011, 01:34:35 AM
LOL, okay maybe I used the wrong term, but a hooter in South Africa would be more accurate for a car..
The hooter went on quite alright, quite a bit louder than the OEM one. I was just interested in what the OEMs db sound went up to?
And to Ninjamudder, thanks for the tip about adjusting it, never knew I could, so I may have it a little louder by the end of the day.
Oh the horn went on alright, quite bigger than OEM so the mounting angle was adjusted slightly.
Quote from: flips on November 03, 2011, 07:45:29 PM
Hi there.
Na the hooter is fine, just pathetically soft
Gotta love the language barrier :rofl:
Post by: fj11.5 on November 09, 2011, 10:52:10 AM
dont need big hooters to make lost of noise, small ones work just as good if the buttons pressed correctly :drinks:
