General Category => Maintenance => Topic started by: Pat Conlon on October 10, 2011, 04:18:41 PM
Title: Valve Stem size?
Post by: Pat Conlon on October 10, 2011, 04:18:41 PM
Hey guys a quick question.
My rear rubber valve stem is leaking so I'm gonna order a aluminum shorty valve stem.
What size do I need? The rear rim is off the 1997 YZF1000 (T-Ace).....I suspect the hole is ~11.0mm (.43") not sure so I thought I would check here.
I see online the valve stems come in different diameters.... I recall the skinny Italian Presta valve stems on my road bicycle.....
I guess I could go out to the garage and cut the stem off and measure the hole but moving that bike around with a flat 180 series tire is a bitch.
Thanks a bunch.
Paddy
[edit] The T-Ace does not require a special size stem, nothing special there,  but IIRC I think all Japanese bikes use the same universal size stem.
Title: Re: Valve Stem size?
Post by: ribbert on October 10, 2011, 06:17:52 PM
Quote from: Pat Conlon on October 10, 2011, 04:18:41 PM
Get a standard ( car size ) 90 degree. I had the right angle stems fitted on my last tyre change and it makes pressure checking / inflating a breeze. Any tyre fitter will have them on the shelf. About $15.
Post by: Pat Conlon on October 10, 2011, 06:38:31 PM
Quote from: ribbert on October 10, 2011, 06:17:52 PM
Thanks Noel, yea, that's the plan....a 90* fitting up front where it's hard to squeeze my hand between the sharp edged 320mm rotors and the rim.
In the back I have plenty of room so I going to go with a straight shorty.
I'm ordering online with multiple choices of size....none of which are labeled "standard car size"....hence the question...Cheers!
Post by: miked on October 11, 2011, 12:21:38 AM
Hi Pat,
Just measured one for you. Mine are 11.5mm (.453").
Standard car size is called a TR13 (which fits above).
Hope this helps.
Mike
Post by: Pat Conlon on October 11, 2011, 12:51:58 AM
Thank you Mike, it helps a bunch.  Pat
