General Category => Modifications => Topic started by: jonaf on May 17, 2009, 01:43:40 PM
Title: Taller gearing
Post by: jonaf on May 17, 2009, 01:43:40 PM
I currently run sprocket/chainwheel = 18/39teeth but my grunty motor could use even taller gearing. Some FJR1300s use a 38t chainwheel. I wonder if this has the same bolt pattern as the FJ's?
Title: Re: Taller gearing
Post by: the fan on May 17, 2009, 01:55:05 PM
why not go aftermarket? here in the USA JT offers the rear in sizes ranging from 38 to 49 in steel and aluminum.
Isn't the FJR 1300 shaft drive?... :biggrin:
Post by: jonaf on May 17, 2009, 02:32:04 PM
Quote from: the fan on May 17, 2009, 01:55:05 PM
Oops, did it again... I did of course mean XJR1300  :dash2: Thanks for the tip - I think it may be a good idea to place an order with JT
