General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: Carterc on June 07, 2011, 07:45:57 PM
Title: Knock knock...
Post by: Carterc on June 07, 2011, 07:45:57 PM
So i started up my bike today and my father pointed out a knocking sound that was in tune with with the shaking of the engine, if that makes sense. Im assuming this is a big problem... Please inform.
Title: Re: Knock knock...
Post by: Travis398 on June 07, 2011, 08:03:40 PM
does the sound go away or get worse when you ride it at higher rpm's?
Post by: Carterc on June 07, 2011, 08:08:17 PM
I have no idea, my bike is to loud to hear it, i can only audibly hear it when i idles
Post by: andyb on June 07, 2011, 10:00:23 PM
Camchain, starter chain, loose engine mount.
Less likely but more expensive is a bearing someplace.
Post by: racerman_27410 on June 08, 2011, 09:05:27 AM
what RPM is your idle set ?
the FJ likes to idle about 1100 RPM.... lower idle speeds can result in all kinds of weird (  but normal)  noises
Post by: Scooterbob on June 08, 2011, 11:19:48 AM
Loose exhaust possibly?  Cracked or loose fairing?  Trying to narrow down a knock or vibration on the FJ seems to be a "needle in a hay-stack" kind of thing.
Let us know what you find.   (popcorn)
Post by: Carterc on June 08, 2011, 11:43:08 AM
rpm is set at 1100 and the knock is definitely in the engine, i put a long screw driver on the engine block and listened to it by putting my ear on the end of the screw driver (poor mans stethoscope). Also, today i took the bike to work and when i got here it was smoking from the engine..... I'm no mechanic and I'm about to give up on this bike, this is ridiculous.
Chris
Post by: Travis398 on June 14, 2011, 07:27:13 PM
As Andy and Frank said it's not very likely to be anything more than weird/normal noises. As far as the smoking goes, your bike is 25 years old, a small oil leak is nothing to panic over. It is pretty common for the rubber seals on the valve cover bolts to dry out and leak, be a shame to give up over a $3 rubber seal.
Post by: RichBaker on June 14, 2011, 07:54:14 PM
Quote from: Carterc on June 08, 2011, 11:43:08 AM
Chris
Even when properly set, the clutch basket and cams both rattle and clatter a bit at idle....
Post by: nvmike24 on June 20, 2011, 11:38:13 AM
 :music: have you synced the carbs? Low idle and carbs out of sync will make primary chain racket. I agree on the smoke issue, she be an old girl. Being loud does not prevent poor mans hearing aide from working. Bump the idle up to 1500-2000 and see what area you can find the noise loudest.
ps: what's the asking price? Just yankin your chain. Relax
Post by: Carterc on June 20, 2011, 12:31:30 PM
thanks for all the help guys.
btw, the asking price is $1,000,000.00..... :rofl:
Post by: Scooterbob on June 20, 2011, 01:28:37 PM
Quote from: Carterc on June 20, 2011, 12:31:30 PM
Take a check?   :lol:
Post by: Travis398 on June 20, 2011, 02:48:05 PM
I like that  :good:
