General Category => General Discussion => Topic started by: Scooterbob on February 17, 2011, 10:20:06 AM
Poll
Question: How would you fix a flat tire?
Option 1: Patch votes: 7
Option 2: Plug votes: 5
Option 3: Buy New votes: 5
Option 4: Sell Bike! votes: 1
Title: Flat Tire - Patch, Plug or Buy New?
Post by: Scooterbob on February 17, 2011, 10:20:06 AM
Got a small screw in my one month old front tire.  I've already done a quick search, but didn't find any answers I liked.  I guess my main question is to Patch it, Plug it, or Buy New?  Obviously the "buy new" is the best, but not the most cost effective.  Feel free to include known dangers, forseen problems and long term effects when giving your answer.
Much appreciated!
Title: Re: Flat Tire - Patch, Plug or Buy New?
Post by: moparman70 on February 17, 2011, 10:50:38 AM
Quote from: Scooterbob on February 17, 2011, 10:20:06 AM
Much appreciated!
I have plugged my rear tire with no issues at all and it was almost new when done.  I am thinking the front I might patch -- as they are a little more susceptible to pressures of braking etc..... although pulling the tire off --- ahhh plug it ....
steve
Post by: Scooterbob on February 17, 2011, 11:02:45 AM
QuoteI have plugged my rear tire with no issues at all and it was almost new when done.  I am thinking the front I might patch -- as they are a little more susceptible to pressures of braking etc..... although pulling the tire off --- ahhh plug it ....
steve
I pulled mine off the rim manually and then put a patch from the inside, since it was just a little off center of the main contact strip.  Otherwise I would probably go new.  I know plugging is easy (that's what she said!) but I just don't trust it to stay in long term.
Post by: Coronet on February 17, 2011, 11:40:47 AM
 Actually installing a plug works really well if done right and the correct plug used. The patch also works well but attention to detail and prep of the tire lining as well as the quality of the patch can make make or break this deal. If you used a cheap patch kit and /or did not prep the inside of the tire correctly the patch most likely will start coming loose and leaking.
I only say this as I did a stint for Firestone Tire Co. worked there about 8 yrs. (back in the 80's) and trust me I seen it all.
Mark H.
Post by: Pat Conlon on February 17, 2011, 12:36:11 PM
Depends on the damage from the screw.
As you described a small screw in the tread of the tire is probably ok, (as opposed to a screw in the sidewall)
1) On the road, a Stop and Go mushroom plug I have found is the best type of plug for sealing the tire.
http://www.racerpartswholesale.com/category/Stop_and_Go/?r=gsng&gclid=CJOf98Dqj6cCFQcObAod5wEOcQ (http://www.racerpartswholesale.com/category/Stop_and_Go/?r=gsng&gclid=CJOf98Dqj6cCFQcObAod5wEOcQ)
The only problem with these mushroom plugs is that with very small punctures, you have to ream out the puncture (sometimes, a lot) to get the plug nozzle into the tire carcass to insert the mushroom. You can cut the tire's radial cords when doing this reaming, weakening the tire.
2) If you are at home, or near a shop, don't plug the tire. Dismount it and take it in for a patch. For a small puncture on the tread, you will be fine with a patch for street riding (not so for track days, where you need to replace the tire)
Pat
Post by: Travis398 on February 17, 2011, 03:13:28 PM
I vote for patch, as Pat said, putting a plug in requires you to ream or cut the rubber and possibly cutting the tires radial cords or stretch them considerably.
if it were my pick up truck I would plug it in a second, but the front tire of a bike that you may or may not do 100+ mph  :negative:
if you find someone who knows what they are doing, they will buff the tire and cement a patch on without a problem.
a new tire works too.
Post by: Scooterbob on February 17, 2011, 03:30:59 PM
The patch is on it now. We'll see how long it lasts. At least long enough to order another tire and get it delivered I would hope.
Post by: RichBaker on February 17, 2011, 06:22:40 PM
Most MC tire manufacturers recommend a patch-plug..... it's a patch with a plug sticking out the middle of it. They also recommend derating the speed a step.
(http://www.allbatterysalesandservice.com/prodimg/BJ561.jpg)
Post by: andyb on February 17, 2011, 06:27:20 PM
I've used a patch-plug on a motorbike tire and had very good results with it.  If I was road racing or otherwise using 100% of my tire's capabilities, I'd probably prefer to replace it, but I'd be a very good pro-level racer.  Not very likely, sadly, so I used the funny patch and it worked quite well for the 1500 miles worth of life that tire had left.
Post by: FJ Flyer on February 18, 2011, 07:47:35 AM
I just found a nail in my new Angel rear tire yesterday.  Got to work, was waiting for the garage to open and had a 'lo press' warning for the rear tire.  Found the nail to left of center in the main tread area.  Mother....  It had about 20 psi.  Felt a little squirrely on the ride in, but I'm still getting used to the Angels.
Pulled out the compressor and pumped it up to about 30 psi before the garage opened.  Had to leave at lunch and it still had about 25 psi when I went to leave.  Pumped it back up to about 35 psi and a buddy lent me a can of fix a flat just in case, and I also have a plug kit on the bike.  Made it home and only lost about 1 psi.
Picked up some patches last night and will pull the wheel and tire and see how it goes.
Post by: Scooterbob on February 18, 2011, 08:30:53 AM
It's a crappy feeling when a tire goes down on a motorcycle. Sorry to hear it. The front tire I had to patch is only about a month old. That hurt even worse.
I was surprised at how easy it was to get the tire on and off the rim manually. I had more trouble getting the bead to grab enough to start building pressure! Ended up putting a strap around outside edge of tire and then tightened the strap enough to mushroom to bead into place and then it started taking air. That was my only pain during the process.
Post by: Rich Pleines on February 18, 2011, 08:44:54 AM
From the Dunlop Information Center
Question.
Can I have my motorcycle tires repaired?
Answer.
Some punctures in motorcycle tires can be repaired if no other damage is present. Dunlop recommends only individual permanent plug-patch repairs of small tread area punctures from within the demounted tire by a qualified tire repair shop or motorcycle dealer. Never perform an exterior repair and never us an inner tube as a substitute for a proper repair. Your bike should not exceed 50 mph for the first 24 hours after the repair and the repaired tire should never be used over 80 mph. Dunlop speed ratings are voided by repairs.
No form of temporary repair should be attempted because secondary damage caused by the penetrating object may not be detected and tire or tube deflation may occur at a later date.
Dunlop does not recommend the use of liquid sealants. These are a form of temporary repair that may adversely affect ply material and mask secondary damage caused by the penetrating object. Reliance upon sealants can result in sudden tire failure and accident
My vote is to replace the tire ASAP. For the price of a tire I would rather not would worry about it and I would worry about it.
:bomb:
Post by: Scooterbob on February 18, 2011, 09:23:45 AM
Good thing mine is an Avon and not a Dunlop!   :lol:
Post by: the fan on February 18, 2011, 10:24:28 AM
Not sure if they are still doing it, but Avon tires offered a road hazard warranty a few years ago.
I never trust a plug or patch. If I have to repair a tire I replace it asap.
Post by: Mark Olson on February 18, 2011, 01:12:15 PM
 Buy a new tire.
I get mine at cyclegear and add the road hazard warranty.
a plug is ok to get ya home but I don't trust them at speed.
there is enough to worry about when you ride , don't add a cheesy tire repair to the list.
Post by: ddlewis on February 18, 2011, 01:50:07 PM
it physically pains me to throw away a good looking tire over a nail puncture, but I do it.  that's one thing you don't want on your mind while your leaned over in 60mph sweeper.
couple years ago tossed out a 5 day old Metzler Tourance ($150)..  I'm still not over it.   :empathy3:
Post by: Yamifj1200 on February 18, 2011, 02:53:13 PM
" I'm still not over it.  "
I know its hurts to replace a new tire that gets punctured, but it would hurt alot more to damage ones ass or bike for the sake of a new tire.
Hows the new bike riding Dan?
Eric M
Post by: ddlewis on February 18, 2011, 04:45:18 PM
Quote from: Yamifj1200 on February 18, 2011, 02:53:13 PM
... Hows the new bike riding Dan?
Eric M
Sweet!  I just rolled her into the garage, couldn't let this 75F get by without a tour de matoaca..
Post by: racerman_27410 on February 19, 2011, 01:06:05 AM
i will run a patch/plug in the rear but in the front i would get a new tire.... surpisingly i've never had a front get a puncture (knock on wood)
Post by: craigo on February 21, 2011, 11:31:09 AM
Well it just happened to my brand new 17" rear tire.  I popped her off the center stand and @#$^%$&*($)$% flat as a pancake. :mad:.  Thing is, I just had to plug one of my car's tires for the same thing.  Guy that lives in the house in front is in construction.  Seems hardware is falling off his truck onto our gravel driveway.  One flat, well could have been anywhere.  2 flats inside a week.  Has to be him.
Gonna have to have a talk with him and comb my driveway with a magnet.  :ireful:
CraigO
90FJ1200
Post by: Scooterbob on February 21, 2011, 12:07:02 PM
That really sucks. I'd say you should remove all the valve stems on his tires and maybe he'll get the idea.
I see that 50% of the voters would go with a patch now. I know the saying is "if you can't afford the parts, you don't belong having a motorcycle", but I totally don't agree with that saying. I got the FJ because I love them, they're dependable, and it was an inexpensive investment on a daily driver. Coughing up $120 on a new tire just hurts beyond money. My tire is barely 2 months old. I understand the results of a blown tire, but I don't believe a hole that was the size of a tack being patched is a very high risk. I will run the tire with the patch until it either wears out or goes flat again, just like any other tire. Crazy? Maybe. I get called that every day I ride in Houston traffic.
Post by: craigo on February 21, 2011, 12:23:22 PM
Bob,
That's a great idea about the valve stems.  but first I have to prove it.  I need a strong magnet to rake thru the gravel at the end of the driveway.  If I find a bunch of nails, I will give him the bill for a new tire.  If he refuses to pay for it, then the valve stems go.  :diablo:  Then, I'll just have the tire patched.
If I was going to ride her on the sunny side of 100mph, I'd buy a new tire.  But I so rarely go that fast anymore, I feel I can risk a patch.  (7 come 11, baby)....
And I totally agree with you on the reasons of having the FJ also.  I love them.
CraigO
90FJ1200
Post by: Scooterbob on February 21, 2011, 12:47:48 PM
Quote from: craigo on February 21, 2011, 12:23:22 PM
Bob,
CraigO
90FJ1200
How bout just one valve stem?  He might be more inclined to help you look for nails in the area that way.   :biggrin:
Post by: FJmonkey on February 21, 2011, 06:59:19 PM
Quote from: Scooterbob on February 21, 2011, 12:47:48 PM
Bob,
CraigO
90FJ1200
Then get him to spring for the cost of the Mag-Rake you had to buy...for his other jobs....He gets to learn how not to piss off other potential customers.
Post by: RichBaker on February 22, 2011, 06:04:59 PM
Quote from: Scooterbob on February 21, 2011, 12:07:02 PM
I've run 2 tires with patchplugs in them, one from a week old to used up, and the other from from ~1/2 used to done-in. Both in rear tires. I would not hesitate to do it again.... But, I wouldn't trust a plain, old-fashion patch, to get me much further than home.  If it's good enough for the tire manufacturer, it's good enough for me....
Post by: Lotsokids on February 22, 2011, 11:14:19 PM
I've used plugs where patches failed on my car. The patch-plug looks like a good idea. I've never seen that. I've plugged a rear tire a few years ago on a CBR 600. I had to really tame down my riding because my faith in my tire was no longer 100%. It held just fine, though.
And yes, the best option is to replace it.
