General Category => Modifications => Topic started by: billwest on January 20, 2011, 12:52:51 AM
Title: Extra clutch spring
Post by: billwest on January 20, 2011, 12:52:51 AM
Gents,
Has anyone ever stripped the thread of the bolts on the plate that hold in the clutch spring?
I'm asking because I didn't torque mine to the required setting (5.8 ft lb).  These bolts seem to turn forever, and I am worried that my torque wrench won't pick up and click on such a light setting.
Bill.
Title: Re: Extra clutch spring
Post by: andyb on January 20, 2011, 08:04:46 AM
Newp, I use a beam-type torque wrench.  And it's a shockingly light amount of torque spec'd.
If you're worried on it, blue locktite won't hurt you at all.
If you've already stripped it, undoubtedly it could be helicoiled, though you'd want to maintain the balance of the assembly, so you'd have to do more than one.
Post by: fj1250 on January 20, 2011, 08:45:16 AM
I've done dozens of these without problem. You'll develop a very strong grip in your left hand though.
Mike C
Post by: billwest on January 20, 2011, 07:08:09 PM
No, not stripped.  I will try a few more turns, I figure if it isn't tightened up as it should be, clutch action will not be correct.
Post by: billwest on January 20, 2011, 11:29:36 PM
Its all good, I used a different torque wrench.
Strong left hand - not too bad with the FJR1300 master cylinder.
Bill.
Post by: fb747 on February 02, 2011, 07:11:02 AM
Quote from: billwest on January 20, 2011, 12:52:51 AM
Gents,
Bill.
I'm in the process of mucking around with my clutch and cant seem to find the torque settings u talk of Bill. My question is, the 5.8 ft lb's u mention above is that the setting only if you add the 2nd spring? or is that the recomended setting for just one spring?
Cheers, Ben.
Post by: billwest on February 02, 2011, 07:48:58 AM
5.8 ft lb, as per the service manual, with the standard single spring.
Bill.
Post by: fb747 on February 02, 2011, 08:40:03 AM
Thanks for that m8, now to scrounge up a torque wrench.
