I am a newbie here hi guys/ i have just got a m reg fj1200 a couple of problems abs light is on but i have noticed the centre of the front wheel where i think the abs senser is/ Is spining free looks like a lug has come of could this be my problem. Also how hard a job is it to replece the swinging arm bushes. thanks for any help
Quote from: and on December 16, 2010, 12:56:22 AM
Have i written or said something wrong i asked a couple questions on this site on 03 dec and had not one reply if the answer i needed is else were in the forum then please sombody at least point me in the rite direction.I posted questions on maintenance and modification topic. :negative:
Sorry for the late reply. I thought someone would have answered your questions by now....
I can not help you with your abs question. I don't have abs on my FJ's
I can help you with your swing arm question.
It's easy to remove and service your swing arm (with the exception of one bolt)
You want to service the roller bearings on the pivot shaft and needle bearings on the relay arm linkage points.
FYI The early FJ's '84/85 had bushings on the swingarm relay arm linkage which needed (seemingly continuous) greasing especially in wet weather climates....
All later FJ's switched over to needle bearings on the relay arm linkage, much better IMHO than the bushings.
So...Here ya go...
1) Put your FJ on the center stand.
2) Remove your back tire.
3) Remove the rear bolt on your rear brake torque arm and, by the hose, hang the caliper and mount arm over right side frame, by the passenger foot peg. No need to undo any brake lines. Just hang the hose over the right side so it's out of the way.
4) Remove the lower shock mounting bolt and dogbones. Your swing arm will now hang down.
5) Loosen and remove the pivot bolt nut and use a punch gently tap the pivot bolt out. Don't worry the swing arm will not fall out at this point.
6) From behind, lift the swing arm pivot shaft area up and back, the swing arm should come free. You may need to wiggle the swing arm pivot shaft up and down to get it loose. In all cases do not pull straight back. You will never get it out. The swingarm pivot shaft has to go UP first.... then pull back.
7) Remove the end cups over the swing arm bearings and bushing to get access and grease away.
8.) Now you have access to the rest of the swing arm linkage to remove, grease and reinstall.
Problem area: If you have the oem exhaust. The relay arm linkage bolt next to the exhaust collector box will require you to remove the exhaust collector box, (i.e.meaning the whole system) so you can get that pesky bolt out. The rear exit ports on the exhaust collector block the path of removal for the bolt. If you have a aftermarket header then you don't have this interference from the collector box and you're good to go.
9) While you're this far, might as well remove your left side cover on the counter shaft sprocket, and remove your chain, for a through cleaning.
10) Reverse this process for reassembly. Remember to reinstall your chain before you reinstall your swing arm.
I bet'cha a jelly donut that I am not the only one who has reinstalled the swing arm and forgot about the chain. :dash2:
Check on FleaBay for Haynes or Clymer FJ service manuals. Get both. Good info. contained therein. Cheers! Pat
yup.... done that...jeez the swing arms neat and tidy.... BUGGER!!!!!!!! :dash2: pass me the sapnners and make some coffee will ya!!! :dash2:
Heh, heh, yea right, you've forgotten more about FJ's than I know.......
thanks for the info its a reat help i will check everything when i can get to my bike under the snow thnks again steve :bye2:
