I just brought home an '84 FJ with 51,000 miles. The guy I bought it off of had it for a year or two and only put about 1000 miles on it. The only maintenance he did on it was an oil change and new plugs when he got it. Before that, it's maintenance history is unknown.
The guy told me that it had been running great until the last time he rode it a few weeks ago when it suddenly seemed to lose power. He thought that it felt like it was only running on three cylinders. He noticed that some oil was dripping from the exhaust collector (low point in the system) and that the #1 cylinder exhaust port area was all oily. The assumption was that the plug had fouled due to the oil in the cylinder.
However, once I got the bike home and did a compression check I found the compression low and all over the board. There is a lot more wrong here than oil consumption. Here's the readings that I got:
#1 - 90psi
#2 - 40 psi
#3 - 60 psi
#4 - 120psi
I tried pouring some 60wt oil into the cylinders and it had no effect on the compression so I assumed that the valves were the problem. I pulled the cam cover to check the valves and discovered that on all four cylinders, ONE of the intake valves had closed up all the way so that there was no clearance at all. The exhaust clearances were all okay, and the other intake valve on each cylinder was a bit tight but at least there was some clearance. Strange.
Being the intake valves, the chances of burning a valve are a lot less than the exhaust valves due to the cooling effect of the incoming charge. Still, I wonder why the clearance closed up like that on only one valve per cylinder and not the other, and whether I'll need to rebuild the head at this point. Has anyone here seen this before?
Here's my plan for now: I'll get one shim, the thinnest size available and use it to get measurements to (hopefully) bring all the valve clearances into spec. Hopefully the valves/seats aren't burn and ruined and this will fix the compression problems. Once the valves are right I'll try to run the bike and try to figure out the cause of the oil-in-the-exhaust problem.
Does this seem like a sound plan? I'm new to this type of bike. I'm used to early-'70s twins and singles with screw-adjustable valves. Any advice or insight would be appreciated. Thanks.
Actually, the more that I think about it, the more I think that I might go with a different approach. I think that I'll just suck it up and pull the head off. That way I can examine the bores, check the valves, lap or regrind them depending on their condition, check the valve guide clearance and correct if necessary, change the valve seals, and eliminate the head gasket as a potential source of the oil problem.
Valve shims aren't cheap and they add up quickly when there's 16 of them. I'd like to keep the swapping of them to a minimum.
Man, I'm used to singles and twins with two valves per cylinder (...or none at all. I have a lot of 2-strokes). Things are a lot cheaper when you aren't looking at 4 cylinders and 16 valves. But they're a lot slower, too :)
Did you have the throttle WFO when you were cranking it for the compression readings?
Yup, WFO to the max.
in the first post , you mentioned maybe a plug had fouled . Was that the case? I know you have bad compression but it is the all at once bad running thing that causes a problem.
If a plug fouled and caused the bad running then I could see resetting you're valve clearances and checking compression again, However if there was no bad plug then I think you are looking at a valve job.
when and if you tear it down check piston height on each cylinder , A bad fuel petcock can cause bent rods and a similar compression reading to what you have now. :morning1:
Quote from: Mark Olson on November 22, 2010, 12:56:57 PM
This is good advice. But to put just a bit of a finer point on it, it takes a bum petcock, (or one left on 'prime' -year depending-) AND one (or many) bad float needle seat o-rings which allow additional fuel passed once the bowl is full. This allows the cylinder(s) to fill with excess fuel, and the rod to bend when you try to start it.
While you're at re-doing the top-end, order yourself one of David R.'s (OLDSLOWGUY) excellent stainless steel, allen-head screw and o-ring kits, and go through the carbs as well. Sounds like it would not be an issue for you.
Welcome here, by the way.
Quote from: Dan Filetti on November 22, 2010, 06:09:46 PM
And maybe this confirms the above...... in the original post:
"He noticed that some oil was dripping from the exhaust collector"
I wonder if this was in fact fuel mixed with exhaust pipe carbon?
Quote from: Harvy on November 22, 2010, 06:53:25 PM
I wondered about that when I first read his post as well.
this would definitely explain the "it was running fine right up until ... it wasn't" statement
Thanks for the tips. I sure hope that I don't have any bent rods...that would be stinky. I have the head ready to pull at this point and I have a few theories that I need to investigate. The oil in the header might be a partial fluke... the sump and oil cooler lines are leaking and I think that they were the origin of the oil leak my buddy identified. There was a LOT of totally unburnt, clean oil in the header. I think that what might be happening is oil leaking from the sump and cooler lines is getting into the header collector through a rust hole, maybe. The collector area is really greasy and oily and covered in gravel and road bits. I need to clean it off and take a look. Still, there's evidence of some oiling from the #1 cylinder, though I don't think it's as severe as I first thought. The plug that came out of that cylinder looked good, though I didn't check it for spark.
I really just need some time to work on the thing. I should have enough time this holiday weekend to really get some answers. I'll report back when I figure out more.
One more thing to check. If you did flood a cylinder with fuel, then your oil would likely have a distinct smell of fuel. Rings with 51,000 miles will allow some fuel by for certain.
If your oil does not smell like fuel, then the flooded cylinder idea may not be correct.
Just another thought.
With the head off, you could probably measure how far the pistons are in the hole. If there's one that's way off, start guessing at a bent rod. Likely not though.
I had the valve problem you speak of. My valves were not seating but somehow the engine still ran. There was a thin layer of carbon on the valve seats and no clearance between the shim and lobe. I reworked the head and installed new exhaust valves then I fiddle farted around with the shims for a few hours before I finally took a measurement from the empty bucket to the cam lobe and realized my valve seats were worn out. I ended up replacing my cylinder head. If you need some thin shims let me know and we can do some trading.
Good news...I pulled the head off tonight and all the pistons have healthy and proper compression height. Man, I am relieved. Not only that, but the pistons and bores look astonishingly good for having 51,000 miles. The crosshatch pattern in the bores is still clearly visible and there is no ridge at the top of the cylinders apart from a thin layer of carbon.
Is it normal for the bores to still show the crosshatching at this mileage? Since the history of the bike is unknown, I suppose that it could have had top-end work done in the past.
At this point I feel pretty confident that the compression problems are due to the intake valves not closing completely. This weekend I'll take the head apart and take a look at everything. I'm hoping that a good lapping will set them right and the guides are in good shape and I can put the thing back together with some new valve seals.
I sure am happy that the motor didn't have the dreaded hydro-lock bent rods. I will sleep well tonight, dreaming of a healthy FJ.
Quote from: TheRadBaron on November 23, 2010, 09:11:43 PM
Well that's a load off your mind.
I remember Frank M telling very early in my ownership of the FJ that the cross hatching on the bores from the factory was pretty decent (for want of a better way of putting it). I believe he was quoting Hank Scott at the time.
Just curious, knowing that the intake valves were not correct, why didn't you fix that then re-test?
Be sure to replace the rubber seals on the oil galleys and dress up the copper head washers with some sandpaper so they re-seal. You'll also need a new cam chain tensioner gasket, and of course a new head gasket.
Check the valves for pitting on the seat face. You can lap them, but you can NOT grind the valves, they are surface hardened and you'll grind right through the tough zone. I had bad pitting on my '85 and replaced the set with SS valves.
It's probably a good time to replace the valve cover gasket and the rubber seals on the cam cover bolts. See RPM Randy for parts.
At 20k (and comfortably over 100 dragstrip passes) when I tore mine apart, the crosshatch was pretty clear and the cylinders looked quite good. Can't say I'm surprised if they still look good at 50k. Guessing that the problem's the valves not sealing, fix that and do valve seals while you're there, degree the cams in, and I'd bet you'll find the problem pretty well licked.
That's the plan. Hopefully it all works out.
I mainly decided to pull the head just to put to rest any fears I had of the engine's condition and do some maintenance on the head. Now I know that the pistons and bores at least appear to be in top shape and I can go through the head and freshen it up. This could be easier than I thought. Then again, it might not be...
Quote from: SlowOldGuy on November 23, 2010, 10:48:25 PM
Thanks David.
TheRadBaron,
For your information I sell an upgraded valve stem seal that will out live the stock seal indefinitely. I also have any and all of the other parts needed to do any head work you need.
rpm@swaybar.com
Thanks Randy, the check's in the mail. I haven't started the cylinder head disassembly yet, but I think I found the cause of the "suddenly started running poorly" problem.
I started to go through the carbs and I found that the #1 carb had a corroded jet needle and it was stuck firmly in the needle jet. I had to pop the slide out of the carb body with a screwdriver. The slide was all the way down, so the #1 cylinder would never have gotten much more "throttle" than idle. That would explain why my buddy said that it felt like it was running on 3 cylinders.
I wonder if it's a coincidence that the #1 cylinder was the one that appeared to be passing some oil into the exhaust. Could the closed carb have done something weird to the vacuum in the cylinder while the rest of the motor was at high load/high RPM that could cause it to suck oil? So I guess that I'll be needing a new needle and needle jet. Is there a source for these parts that's cheaper than Yamaha? Sudco, maybe?
One more carb question...I know that on the old singles and twins I'm used to, the needle and needle jet can get beat up over the years due to the engine vibration. The damage is not readily visible, but it effects running. Would it be advisable to change the needle and jet in all 4 of my carbs? I know that a 4-cylinder vibrates a lot less than a twin, so maybe it's not too much of a concern. I'd rather not spend the money if I didn't need to.
The needle and emulsion tubes are a high wear item. I have all of the carbs parts in stock and cheaper than all of the rest. But with the parts you are talking about plus the other wear items, it will probably be cheaper and easier to start of with a brand new set which I can supply as well for $400.00
I will not be back to the shop until Thursday, so if you get them torn down completely and inspected, make a list and I can shoot you the prices and you can make your determination.
be interesting to know as you say if the carb blockage was making no 1 drag through its cycle, maybe dredge up some oil through the rings or down through the stem seals..... but i got my own oil leaks to worry bout :mad:
Quote from: TheRadBaron on November 29, 2010, 05:33:50 PM
High rpm with closed throttle blades (trailing throttle, usually) and/or a slide stuck firmly down would both give the same effect; very high vacuum on the intake cycle. Valve seals are often weak link when it comes to handling that much vacuum, so not a huge surprise on greasing that hole.
That's pretty much what I was thinking. I got the valves all taken out of the head and they all look very good. There's some carbon on the intake valve seats that weren't closing all the way, but there is no visible pitting anywhere. I'll be lapping them with some fine-grit lapping compound and I think that they'll be ready to go.
The stock valve seals were not in good shape and looked to be a poor design to me. I've got some replacements from Randy that will be going in soon.
I'm currently soaking the valve heads, combustion chambers, and ports with Sea Foam to soften up the carbon deposits before I attack them with a brass bristle brush.
I'm pretty pleased with the way everything is going so far. Instead of one big problem with the motor that I had feared, it looks like it just had a few minor problems that will be (relatively) cheap and easy to fix.
